Learn how to automate the process of adding Instagram Lead Ads leads to AITable.ai using Pabbly Connect. Follow this detailed step-by-step tutorial. Master proven automation processes with practical implementation examples and strategic recommendations you can apply immediately in your workflow.
To integrate Instagram Lead Ads with AITable.ai, the first step is to access Pabbly Connect. Visit the Pabbly Connect website and log in to your account. If you are new, you can sign up for free and receive 100 tasks monthly.
Once logged in, you will see the dashboard. Here, click on the ‘Access Now’ button under Pabbly Connect. This action will redirect you to the Pabbly Connect dashboard, where you can create your automation workflow.
After accessing the dashboard, the next step is to create a workflow. Click on the ‘Create Workflow’ button located at the top right corner. A dialog box will appear, prompting you to name your workflow. Enter a name like ‘Add Instagram Lead Ads Leads to AITable.ai’. using Pabbly Connect
  • Select a folder for your workflow to keep it organized.
  • Click on the arrow to choose from existing folders.
  • Finally, click ‘Create’ to finalize your workflow.
Your workflow is now created, and you will see two sections: Trigger and Action. The trigger will be set for Instagram Lead Ads, while the action will be for AITable.ai.
To set up the trigger, click on the trigger section and select ‘Instagram Lead Ads’ as your trigger application. Then, choose ‘New Lead’ as the trigger event. This means that every time a new lead is generated, it will trigger the workflow.
After selecting the trigger, click on ‘Connect’ to link your Instagram Lead Ads with Pabbly Connect. A new window will prompt you to add a new connection. Follow the instructions to authorize your Instagram account, ensuring it is linked to your Facebook page where the lead ads are running.
4. Configuring the Action in Pabbly Connect
Next, you need to configure the action. Click on the action section and select ‘AITable.ai’ as your action application. Choose ‘Create a Record’ as the action event. This action will create a new record in your AITable.ai account whenever a lead is captured. using Pabbly Connect
Click on ‘Connect’ and add a new connection. You will need to provide your API token from AITable.ai. To find this, log into your AITable.ai account, go to your profile settings, and copy the API token. Paste this token back in Pabbly Connect and click ‘Save’.
  • Select the appropriate space and data sheet in AITable.ai.
  • Map the fields for full name, email, and mobile number from the trigger step.
  • Click ‘Save and Send Test Request’ to ensure everything is working.
Once you confirm the action is set up correctly, you can test the workflow by generating a test lead.
To test the integration, use the lead ad testing tool to generate a test lead. Select your Facebook page and the lead form you created. Fill in the required fields, such as full name, email, and phone number, then submit the form.
After submitting, go back to Pabbly Connect and check if the test lead has been captured. You should see the details reflected in your AITable.ai data sheet, confirming that the integration works successfully.
Repeat the test if necessary to ensure reliability. This process demonstrates how Pabbly Connect can seamlessly connect Instagram Lead Ads with AITable.ai, automating your lead management process.
In this tutorial, we explored how to use Pabbly Connect to automate the process of adding Instagram Lead Ads leads to AITable.ai. By following the steps outlined, you can streamline your lead management and enhance your business efficiency.
