Learn how to automate sharing Facebook page posts on LinkedIn company pages using Pabbly Connect. Step-by-step guide for seamless integration. This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
1. Setting Up Pabbly Connect for Facebook and LinkedIn Integration
To start integrating Facebook page posts with a LinkedIn company page, you need to access Pabbly Connect. This powerful automation tool allows you to create seamless workflows between different applications. Begin by navigating to the Pabbly Connect homepage and either sign in or sign up for a free account.
Once logged in, you will have access to various applications offered by Pabbly Connect. To create your workflow, click on the ‘Create Workflow’ button located in the top right corner. You will then be prompted to name your workflow, such as ‘Share Facebook Page Post on LinkedIn Company Page’. Select the appropriate folder for organization and click on ‘Create’.
2. Connecting Facebook Pages in Pabbly Connect
In this step, you will set up Facebook Pages as the trigger application in Pabbly Connect. Select Facebook Pages from the list of applications and choose the trigger event as ‘New Post’. This means that every time a new post is created on your Facebook page, it will trigger the workflow.
  • Select ‘New Post’ as the trigger event.
  • Click on connect and choose ‘Add New Connection’.
  • Authorize Pabbly Connect to access your Facebook account.
After successfully connecting, select the Facebook page you wish to monitor. In this case, you will choose ‘Sparkle Evenings’. Click on ‘Save and Send Test Request’ to complete the setup of the trigger.
3. Creating LinkedIn Post Action in Pabbly Connect
After setting up Facebook Pages as the trigger, the next step involves configuring LinkedIn as the action application in Pabbly Connect. Choose LinkedIn and select the action event ‘Create Company Text Post’. This action will allow you to share the content from your Facebook post directly to your LinkedIn company page.
Click on connect and select ‘Add New Connection’ to link your LinkedIn account with Pabbly Connect. Once authorized, you will need to fill in the details for the LinkedIn post:
  • Enter the organization name as it appears on LinkedIn.
  • Map the content from the Facebook post to the LinkedIn post.
  • Provide a URL for article preview and a title for the LinkedIn post.
After filling in these details, click on ‘Save and Send Test Request’ to ensure that everything is functioning correctly.
4. Testing the Integration Between Facebook and LinkedIn
With both applications configured, it’s time to test the integration using Pabbly Connect. Create a sample post on your Facebook page, such as announcing a Christmas party, and publish it. This action will trigger the workflow you set up.
After posting on Facebook, return to Pabbly Connect to check if the response has been captured. You should see the details of the new post, including the content and post ID. This confirms that your Facebook page is correctly linked to Pabbly Connect.
Next, check your LinkedIn company page to verify that the post has been successfully shared. You should see the same content along with a link to your Facebook page. This step confirms that the integration is working as intended, allowing for seamless sharing between platforms.
5. Conclusion: Automating Facebook and LinkedIn Integration with Pabbly Connect
In this tutorial, we demonstrated how to automate the process of sharing Facebook page posts on a LinkedIn company page using Pabbly Connect. By following the steps outlined, you can ensure that your social media presence is synchronized effortlessly.
Utilizing Pabbly Connect for this integration not only saves time but also enhances your marketing efforts by reaching your audience across multiple platforms simultaneously. Start using Pabbly Connect today to streamline your social media automation!
