Learn how to instantly generate social media posts from WordPress blogs using Pabbly Connect. Step-by-step guide to automate your social media sharing. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
To start automating the process of generating social media posts from your WordPress blogs, the first step is to access Pabbly Connect. Simply open your browser and visit the Pabbly Connect website. You will find options to sign in or sign up for a free account.
Once you have signed in, navigate to the all apps page and click on the ‘Access Now’ button under Pabbly Connect. From here, you can create a new workflow that will link your WordPress blog with various social media platforms.
In this section, we will create a workflow that connects WordPress with social media platforms. Click on the ‘Create Workflow’ button and name your workflow appropriately, such as ‘WordPress to Social Media Automation’. This name helps identify the workflow’s purpose. using Pabbly Connect
- Name your workflow for easy identification.
- Select the folder in your Pabbly Connect account for organization.
- Click ‘Create’ to finalize your workflow setup.
Now that your workflow is set up, you will see two windows: one for triggers and another for actions. The trigger will be your WordPress site, which will activate the workflow whenever a new post is published.
3. Connecting WordPress to Pabbly Connect
To connect WordPress with Pabbly Connect, select WordPress as your app in the trigger window. Choose the event ‘New Post Published’ from the dropdown menu. Pabbly Connect will provide you with a webhook URL to be added to your WordPress site.
Before adding the webhook, ensure you have the WP Webhooks plugin installed on your WordPress site. After installing, navigate to the settings of the plugin and select the option to send data. Here, you will add the webhook URL provided by Pabbly Connect.
- Go to the WP Webhooks settings in WordPress.
- Select the event ‘Post Created’ and add the webhook URL.
- Save your settings to complete the connection.
With this setup, every time a new post is published on WordPress, the details will automatically be sent to your Pabbly Connect workflow, triggering the automation.
4. Generating Social Media Posts with AI
Next, we will utilize an AI platform, such as OpenAI or ChatGPT, to generate engaging social media posts based on the content of your WordPress blog. In the action step of your workflow, select OpenAI as the app and choose the action event ‘ChatGPT’. using Pabbly Connect
Connect your OpenAI account to Pabbly Connect by entering your API key. This key can be found in your OpenAI account settings. After connecting, you will need to set a prompt that instructs the AI to create a concise social media post based on your blog content.
Select the AI model (e.g., GPT-4) for generating content. Input a clear prompt for the AI, specifying the desired length and style. Map the blog content from the trigger step to the prompt.
Once the prompt is set, click on ‘Save and Send Test Request’ to generate the social media post. The response will include a concise caption that can be used across various platforms.
5. Sharing Generated Posts on Social Media Platforms
After generating the social media post, the next step is to share it on platforms like Facebook, LinkedIn, and X (formerly Twitter). For each platform, you will need to add an action step in your Pabbly Connect workflow. using Pabbly Connect
Start with Facebook by selecting the app and choosing the action event ‘Create Photo Post’. Connect your Facebook account and select the page where you want to share the post. Map the image URL and the caption generated by the AI to the respective fields.
Connect your Facebook account to Pabbly Connect. Map the image URL and caption from the previous steps. Click ‘Save and Send Test Request’ to post on Facebook.
Repeat this process for LinkedIn and X, ensuring you map the appropriate fields for each platform. Once completed, your automation will successfully share posts across all selected social media channels whenever a new blog is published.
In summary, using Pabbly Connect, you can automate the process of generating social media posts from your WordPress blogs. This integration not only saves time but also ensures your content reaches a wider audience effortlessly. Start automating your social media sharing today!
