Learn how to set up instant WhatsApp alerts for IndiaMART leads using Pabbly Connect and AiSensy. Follow this detailed tutorial for seamless integration. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
To get WhatsApp alerts for IndiaMART leads instantly, you first need to access Pabbly Connect. Start by visiting the Pabbly Connect website and signing in or creating a free account.
Once logged in, you will find the dashboard displaying various Pabbly applications. Click on the Pabbly Connect option to proceed with the integration process. This platform allows you to automate workflows without coding.
After accessing Pabbly Connect, you can create a new workflow for getting WhatsApp alerts. Click on the ‘Create Workflow’ button and name your workflow. Choose a relevant folder to save it in.
  • Name your workflow: How to get WhatsApp alerts for IndiaMART leads instantly using AiSensy.
  • Select the folder for automation.
  • Click on ‘Create’ to initialize your workflow.
Once your workflow is created, you will see two boxes: one for the trigger and another for the action. The trigger will be set to IndiaMART, which will initiate the workflow when a new lead is received.
3. Setting Up IndiaMART as the Trigger Application
In the trigger section of Pabbly Connect, select IndiaMART as your application. Choose the trigger event as ‘New Lead’. This will allow you to receive notifications whenever a new lead is generated.
Next, you need to connect IndiaMART with Pabbly Connect using a webhook URL. Navigate to your IndiaMART account, go to the Lead Manager, and find the option to set up the Push API. Input the webhook URL provided by Pabbly Connect to link the two applications.
4. Testing the Connection with IndiaMART
Once the webhook URL is set, return to Pabbly Connect and click on ‘Test Your Webhook Listener’. This step is crucial to ensure that the connection between IndiaMART and Pabbly Connect is functioning correctly. You should see a success message indicating that the test lead was received.
After testing, you will receive the details of the lead in Pabbly Connect. Make sure to check the response for accuracy. This confirms that the integration is working as intended, and you are ready to proceed to the next step.
5. Setting Up WhatsApp Alerts Using AiSensy
Now, you will configure AiSensy in Pabbly Connect to send WhatsApp alerts. Select AiSensy as your action application and choose the action event as ‘Send Template Message’. You will need to connect your AiSensy account using the provided API key.
  • Enter the campaign name for your WhatsApp alerts.
  • Map the parameters from the lead details such as name, email, and query.
  • Click on ‘Save and Send Test Request’ to finalize the setup.
Once you send the test request, check your WhatsApp to ensure that you receive the alert with the lead details. This confirms that the integration is successful and you will receive instant notifications for new leads from IndiaMART.
By following this tutorial, you have successfully set up WhatsApp alerts for IndiaMART leads using Pabbly Connect and AiSensy. This integration allows you to automate lead notifications seamlessly, enhancing your response time and efficiency.
