Learn how to automate WordPress blog generation using OpenAI and Google Sheets through Pabbly Connect in this detailed tutorial. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
To start automating the generation of WordPress blogs using OpenAI, you need to access Pabbly Connect. First, navigate to the Pabbly Connect homepage by entering the URL in your browser. You will see options to sign in or sign up for free.
If you are a new user, click on the ‘Sign Up for Free’ button to create your account. Once registered, you will receive 100 free tasks each month to explore the features of Pabbly Connect.
After signing in, you will land on the dashboard of Pabbly Connect. Click on the ‘Create Workflow’ option to begin. A dialog box will appear asking for a name for your workflow. Enter a descriptive name like ‘Generate Unique Articles Using OpenAI’ and select a folder to save it.
  • Click on ‘Create’ to open the trigger and action setup.
This setup allows the workflow to capture data whenever a new title is added to Google Sheets, which will then trigger the automation process using Pabbly Connect.
To connect Google Sheets with Pabbly Connect, you will receive a webhook URL. Copy this URL as it will bridge the data transfer. Open your Google Sheets where you want to generate articles.
  • Go to Extensions > Add-ons > Get Add-ons.
  • Search for ‘Pabbly Connect Webhooks’ and install it.
  • Refresh the spreadsheet to see the new option under Extensions.
After installation, set up the initial configuration by pasting the copied webhook URL and specifying which column will trigger the workflow. This connection allows Pabbly Connect to capture data from Google Sheets automatically.
4. Integrating OpenAI for Article Generation
Once Google Sheets is connected, the next step is to integrate OpenAI using Pabbly Connect. In the action step, select OpenAI as the application and choose the action event as ‘Chat GPT’ for article generation.
You will need to connect your OpenAI account by providing the API key. Select the AI model, preferably GPT 3.5 Turbo. Create a prompt that instructs OpenAI to generate an article based on the title from Google Sheets.
Mapping the title dynamically ensures that every time a new title is added, OpenAI generates a unique article. This seamless integration between OpenAI and Pabbly Connect streamlines your blogging process.
5. Posting Generated Articles on WordPress
The final step is to connect WordPress with Pabbly Connect to publish the generated articles. Select WordPress as the action application and choose ‘Create a Post’ as the action event.
Input your WordPress login credentials and the base URL. Map the post title and content fields with the data received from OpenAI. Set the post status to ‘Publish’ to make it live immediately.
After saving and testing this connection, your articles will automatically be posted on WordPress whenever you add a new title in Google Sheets. This powerful capability of Pabbly Connect eliminates manual posting, saving you time and effort.
In this tutorial, we explored how to use Pabbly Connect to automate the generation of WordPress blogs using OpenAI and Google Sheets. By following these steps, you can efficiently create and publish unique articles without manual intervention, enhancing your blogging effectiveness.
