Learn how to generate unique articles automatically using Pabbly Connect with Google Sheets and ChatGPT. Follow our detailed tutorial for seamless integration. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
To generate unique articles using AI, you first need to access Pabbly Connect. This platform enables seamless integration between various applications, including Google Sheets and ChatGPT. Start by creating a free account on Pabbly Connect by visiting their website and signing up.
After logging in, you will be directed to the dashboard. Here, you can create a new workflow to automate the article generation process. Follow these steps to get started:
  • Visit the Pabbly Connect website and sign up for a free account.
  • Log in to your account and navigate to the dashboard.
  • Click on the ‘Create Workflow’ button to start a new automation.
With these steps, you are now ready to set up your first automation using Pabbly Connect.
2. Creating a Workflow for Article Generation
Once you are in the Pabbly Connect dashboard, you can create a workflow to automate article generation. Start by naming your workflow, such as ‘Generate Unique Articles with AI Step by Step’. Next, you will set up the trigger for your workflow. using Pabbly Connect
For this process, select Google Sheets as your trigger application. Choose the event ‘New or Updated Spreadsheet Row’. This means that whenever a new topic is added to your spreadsheet, it will trigger the automation. Follow these steps:
  • Select Google Sheets as your trigger application.
  • Choose the trigger event ‘New or Updated Spreadsheet Row’.
Now, you can connect your Google Sheets to Pabbly Connect by using the webhook URL in your spreadsheet to send data automatically.
3. Setting Up Google Sheets for Automation
After setting up the trigger in Pabbly Connect, you need to configure your Google Sheets to work with this automation. Open your Google Sheets and install the Pabbly Connect Webhooks add-on. This will allow your spreadsheet to communicate with Pabbly Connect.
Once the add-on is installed, go to the add-on menu, select Pabbly Connect, and then click on ‘Initial Setup’. Paste the webhook URL you copied earlier and specify the trigger column, which will be the column where you enter your command (e.g., ‘Yes’). Follow these steps:
Install the Pabbly Connect Webhooks add-on in Google Sheets. Open the add-on and select ‘Initial Setup’. Paste the webhook URL and set the trigger column.
With this configuration, your Google Sheets will now send data to Pabbly Connect whenever a new topic is added, enabling the automation to begin.
4. Integrating ChatGPT for Article Generation
Now that your Google Sheets is set up, it’s time to integrate ChatGPT into your workflow using Pabbly Connect. Select ChatGPT as the action application and choose the event ‘Ask ChatGPT’. You will need to connect your ChatGPT account by providing the API key.
In the action setup, map the fields to pull the topic and instructions from your Google Sheets. This allows ChatGPT to generate an article based on the data from your spreadsheet. Follow these steps:
Select ChatGPT as the action application. Choose the action event ‘Ask ChatGPT’. Map the fields to pull topic and instructions from Google Sheets.
With this setup, ChatGPT will automatically generate articles based on the topics you enter in your spreadsheet, streamlining your content creation process.
5. Finalizing the Automation with Google Drive
The last step in this automation process involves saving the generated articles in Google Drive. In Pabbly Connect, select Google Drive as another action application and choose the event ‘Create File in Specific Folder’. This will ensure that your articles are organized in a designated folder.
Map the fields for the file name and content. This way, each time an article is generated, it will be saved with the corresponding topic name. Follow these steps:
Select Google Drive as the action application. Choose the event ‘Create File in Specific Folder’. Map the fields for file name and content from ChatGPT response.
Once this step is complete, your automation will not only generate articles using ChatGPT but also save them directly to Google Drive, making your workflow efficient and effective.
In this tutorial, we explored how to generate unique articles using AI with the help of Pabbly Connect, Google Sheets, and ChatGPT. By following the steps outlined, you can automate your content creation process, saving time and enhancing productivity. Start leveraging these tools today for efficient article generation!
