Learn how to generate unique articles quickly using Pabbly Connect with Google Sheets, ChatGPT, and WordPress. Follow our step-by-step tutorial for seamless integration. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
1. Accessing Pabbly Connect for Article Generation
To generate unique articles using Pabbly Connect, start by accessing the Pabbly Connect platform. Visit the official website and log in or create a free account. This step is crucial as it allows you to utilize Pabbly Connect’s automation capabilities.
Once logged in, navigate to the Pabbly Connect dashboard. Click on the ‘Create Workflow’ button to start setting up your integration. Here, you will give your workflow a name, such as ‘Generate 100% Unique Articles using ChatGPT’ to clearly define its purpose.
2. Setting Up Google Sheets Integration in Pabbly Connect
In this section, you will set Google Sheets as your trigger application in Pabbly Connect. Select Google Sheets and choose the trigger event as ‘New or Updated Spreadsheet Row’. This ensures that every time a new title is added, it triggers the workflow.
  • Open your Google Sheets, go to Extensions > Add-ons > Get Add-ons, and install the Pabbly Connect Webhooks add-on.
  • Refresh your Google Sheet and navigate to Extensions > Pabbly Connect Webhooks > Initial Setup.
Paste the copied webhook URL in the designated field and set the trigger column to the column where the titles are added. This setup allows Pabbly Connect to receive data from Google Sheets whenever a new title is entered.
3. Integrating ChatGPT for Content Generation
Now, it’s time to integrate ChatGPT to generate articles based on the titles from Google Sheets. In Pabbly Connect, select ChatGPT as your action application and choose the action event as ‘Ask ChatGPT’. This integration allows you to leverage the power of AI to create unique articles.
To connect ChatGPT, you will need to generate an API key from your OpenAI account. After creating the key, return to Pabbly Connect and paste it into the connection settings. Next, set the AI model to GPT-3.5 Turbo for optimal performance.
  • Map the article title from the previous step to the prompt field in ChatGPT.
  • Click on Save and Send Test Request to generate the article.
Once the request is sent, you will receive a response containing the generated article, which is the core output of this integration.
4. Posting the Generated Article to WordPress
With the article generated, the next step is to post it on WordPress. In Pabbly Connect, add another action step and select WordPress as the application. Choose the action event as ‘Create a Post’ to upload the generated content directly to your WordPress site.
To connect WordPress, you will need your WordPress username, password, and base URL. Once connected, you will fill in the details such as post type, title, and content using the mapped data from the previous steps.
Set the post status to publish to make the article live immediately. Click on Save and Send Test Request to create the post.
After successful execution, you should see the new post in your WordPress dashboard, confirming that the integration is working flawlessly.
5. Updating Google Sheets with the Article Link
Finally, to complete the workflow, you will update your Google Sheets with the link to the newly created article. Add a new action step in Pabbly Connect and select Google Sheets again, this time choosing the action event as ‘Update Cell Value’.
Connect to your Google Sheets account and select the spreadsheet and the specific cell where you want to place the article link. Use the mapped data from the previous WordPress step to populate the cell with the link to the article.
Ensure the cell reference matches the location where you want the link to appear. Click on Save and Send Test Request to finalize the update.
With this final step, your Google Sheets will now reflect the link to the unique article generated, completing the automation process.
Using Pabbly Connect, you can efficiently generate unique articles by integrating Google Sheets, ChatGPT, and WordPress. This automation not only saves time but also enhances productivity in content creation. Start implementing this workflow today to streamline your article generation process.
