Learn how to generate unique articles using Google Gemini and Pabbly Connect. Step-by-step tutorial on integrating Google Sheets with Google AI for automated content creation.
Accessing Pabbly Connect for Article Generation
To generate unique articles, first, you need to access Pabbly Connect. Start by opening your browser and navigating to Pabbly’s website. If you don’t have an account, you can sign up for free, which takes only a couple of minutes.
After signing in, click on the ‘Access Now’ button under Pabbly Connect. This action will direct you to the Pabbly Connect dashboard where you can create workflows that integrate Google Sheets and Google Gemini for automated article generation.
Creating a New Workflow in Pabbly Connect
In this section, you will create a new workflow within Pabbly Connect. Click on the ‘Create Workflow’ button. A dialog will prompt you to name your workflow; you might want to name it ‘Generate Unique Articles using Google Gemini’ for clarity.
After naming your workflow, select the folder where you want to save it. Once done, you’ll see two key sections: Trigger and Action. The Trigger will be set to Google Sheets, while the Action will be set to Google Gemini.
Setting Up Google Sheets as Trigger in Pabbly Connect
To initiate the workflow, you need to set Google Sheets as the trigger application in Pabbly Connect. Select ‘Google Sheets’ and choose the trigger event as ‘New or Updated Spreadsheet Row’. This will allow the workflow to trigger whenever a new article topic is added to your Google Sheet.
Next, you need to connect your Google Sheets account with Pabbly Connect. Copy the provided webhook URL and head to your Google Sheet. Go to the Extensions menu, select Add-ons, and then click on ‘Get Add-ons’ to find and install the Pabbly Connect Webhook extension.
  • Open the Pabbly Connect Webhook extension.
  • Set up the connection by pasting the webhook URL.
  • Specify the trigger column (e.g., Column A).
After configuring these settings, test the connection to ensure data can be sent from Google Sheets to Pabbly Connect.
Generating Articles with Google Gemini
Once the trigger is set, it’s time to configure the action to generate unique articles using Google Gemini. In Pabbly Connect, select ‘Google Generative AI’ as the action application and set the action event to ‘Generate Content’. This allows Pabbly Connect to use the article topic from Google Sheets to create a unique article.
To connect Google Generative AI, you’ll need to provide an API key. Log in to Google AI Studio, create an API key, and paste it back into Pabbly Connect. After connecting, set up the prompt for content generation by mapping the article topic from Google Sheets into the prompt field.
  • Select the model (e.g., Gemini Pro) for generating content.
  • Choose the method as ‘Generate Content’.
  • Save and send the request to generate the article.
After sending the request, you will receive a response containing the unique article generated by Google Gemini.
Updating Google Sheets with Generated Articles
The final step involves updating your Google Sheets with the newly generated articles. In Pabbly Connect, add another action step and select Google Sheets. Choose the action event ‘Update Cell Value’ to input the generated article back into your Google Sheet.
Connect your Google Sheets account again and specify the spreadsheet and the cell range where the article should be inserted (e.g., Column B). Map the row index dynamically so that it updates correctly as new articles are generated.
Select the correct spreadsheet (e.g., Unique Articles). Map the row index based on the trigger response. Submit the action to update the cell value with the article.
After executing this action, you will see the generated article appear in your specified Google Sheets cell, completing the automation process.
By following these steps, you can efficiently generate unique articles using Google Gemini and Pabbly Connect. This integration allows for seamless automation of content creation, saving you time and effort while maintaining high-quality outputs.
