Learn how to automate the generation of unique articles using Anthropic’s Claude AI and Pabbly Connect. Step-by-step tutorial for seamless integration. This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
1. Accessing Pabbly Connect to Start Your Automation
To begin generating unique articles, you first need to access Pabbly Connect. This platform is essential for integrating various applications like Google Sheets, Anthropic, and WordPress.
Visit the Pabbly Connect website by typing ‘Pabbly.com/connect’ in your browser. You will see options to sign in or sign up for free. If you are a new user, click on the ‘Sign Up for Free’ button to create your account. Existing users can directly sign in.
Once logged in, you can create a new workflow in Pabbly Connect. Click on the ‘Create Workflow’ button located on the dashboard’s right corner. A dialog box will pop up asking for a workflow name.
Enter a suitable name like ‘Generate Unique Articles using Anthropic and Create Post on WordPress’. Select the folder to save your workflow, then click ‘Create’. This opens two windows: one for the trigger and another for the action.
  • Choose the folder where the workflow will be saved.
  • Click on ‘Create’ to initiate the workflow.
Now, you can set up the trigger and action to automate the article generation process.
3. Setting Up Google Sheets as the Trigger
In this step, you will select Google Sheets as your trigger application in Pabbly Connect. Choose ‘New or Updated Spreadsheet Row’ as the trigger event. This means that whenever a new row is added to your Google Sheets, it will trigger the workflow.
Copy the provided webhook URL from Pabbly Connect and paste it into your Google Sheets add-on. To do this, go to Extensions > Add-ons > Get Add-ons, and install the Pabbly Connect Webhooks add-on. After installation, refresh your Google Sheets and set up the webhook.
  • Install the Pabbly Connect Webhooks add-on in Google Sheets.
  • Paste the copied webhook URL in the initial setup.
  • Set the trigger column to capture new entries.
After completing these steps, your Google Sheets will be connected to Pabbly Connect, ready to send data for article generation.
4. Using Anthropic AI to Generate Content
Next, you will set up Anthropic as the action application in Pabbly Connect. Select ‘Create Completion’ as the action event. This allows you to generate content based on the title you entered in Google Sheets.
Connect your Anthropic account by adding a new connection and entering your API token, which you can find in your Anthropic account settings. Once connected, you can specify the model and prompt for content generation.
Select ‘Create Completion’ as the action event. Map the title from Google Sheets to the prompt field. Set the maximum tokens for the content length.
After setting these parameters, your workflow will generate unique articles automatically based on the titles provided in Google Sheets.
5. Posting the Generated Content to WordPress
Finally, you will set up WordPress as the action application in Pabbly Connect. Choose ‘Create Post’ as the action event. This will allow you to publish the generated content as a new blog post.
Connect your WordPress account by entering the base URL, username, and password. Then, map the title and content generated by Anthropic to the corresponding fields in WordPress. This ensures that every new article is published automatically.
Enter the required WordPress credentials to establish the connection. Map the title and content to the new post fields. Set the post status to draft for review before publishing.
By completing this setup, you will have a fully automated workflow that generates unique articles and posts them on WordPress.
In this tutorial, we demonstrated how to use Pabbly Connect to automate the generation of unique articles with Anthropic AI and publish them on WordPress. This seamless integration streamlines your content creation process, saving you valuable time and effort.
