Learn how to seamlessly integrate Zenler with Instagram Lead Ads using Pabbly Connect. This step-by-step guide covers everything you need for successful enrollment. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
To begin the integration process, you first need to access Pabbly Connect. This platform allows you to connect various applications effortlessly. Start by visiting the Pabbly Connect website and logging into your account.
If you are a new user, you can sign up for free and get access to multiple tasks each month. Once logged in, navigate to the dashboard where you will see various Pabbly tools. Click on Pabbly Connect to begin creating your automation workflow.
After accessing Pabbly Connect, you will need to create a new workflow. Click on the button labeled ‘Create Workflow’. You will be prompted to name your workflow. For this integration, name it something like ‘Enroll Zenler User from Instagram Lead Ads’.
Once named, select the folder where you want to save this workflow. After saving, you will be directed to the workflow window where you will set up the trigger and action. The trigger will be set to Instagram Lead Ads, which is essential for capturing new leads.
- Select Instagram Lead Ads as your trigger application.
- Choose the trigger event as New Lead Instant.
- Connect your Instagram account to Pabbly Connect.
After these steps, you will be ready to configure the lead form that will be used to capture the information of new leads.
Configuring Instagram Lead Ads in Pabbly Connect
In this section, you will configure Instagram Lead Ads to work with Pabbly Connect. After selecting Instagram Lead Ads as your trigger, you will need to establish a connection. If you haven’t connected your Instagram account to Pabbly Connect yet, do so by adding a new connection.
Once connected, select your Facebook page associated with the Instagram account and the specific lead form you are using. This form is critical as it captures user details when they submit their information through your Instagram ads.
- Select your Facebook page, e.g., Sports Elite Training Center.
- Choose the lead form you created for the online course.
- Click on Save and Send Test Request to ensure everything is working.
After saving, you will need to test the submission to ensure Pabbly Connect captures the lead data correctly.
Enrolling Users in Zenler through Pabbly Connect
The next step is to enroll leads captured from Instagram Lead Ads into your Zenler course. In this step, you will select Zenler as your action application in Pabbly Connect. Choose the action event as ‘Enroll User to a Course’.
To connect your Zenler account, you will need your API key. This can be found in your Zenler account settings. Paste this API key into Pabbly Connect when prompted. Make sure to enter your school name correctly as well to establish a successful connection.
Enter your Zenler API key and school/account name. Select the course you want to enroll users in. Map the user details such as email, first name, and last name from the lead data.
After mapping the user details, click on Save and Send Test Request to finalize the enrollment process. If successful, you will see a confirmation message in Pabbly Connect.
Testing and Verifying the Integration
After setting up your workflow in Pabbly Connect, it is crucial to test the integration to ensure everything works smoothly. You can do this by submitting a test lead through the Instagram Lead Ads form. This submission will trigger the workflow you created.
Once the test lead is submitted, return to Pabbly Connect and check if the lead data has been captured correctly. You should see details like the first name, last name, email, and phone number in the workflow response.
Check if the lead appears in your Zenler course. Verify that the confirmation email was sent to the new user. Repeat the test with different leads to ensure reliability.
By following these steps, you can ensure that your integration between Instagram Lead Ads and Zenler through Pabbly Connect is functioning correctly.
In this tutorial, we explored how to enroll Zenler users automatically from Instagram Lead Ads using Pabbly Connect. This integration allows for seamless lead management and course enrollment, enhancing your lead nurturing process. By following the outlined steps, you can effectively engage with your audience and offer them valuable courses.
