Learn how to automate user enrollment in ThriveCart Learn+ using Instamojo Payments with Pabbly Connect. Step-by-step tutorial for seamless integration. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
To start automating user enrollment in ThriveCart Learn+ using Instamojo Payments, you first need to access Pabbly Connect. Open your browser and search for Pabbly Connect to reach the landing page.
Once on the Pabbly Connect page, you have two options: sign in or sign up for free. If you don’t have an account, click on the ‘Sign up for free’ button, which takes just two minutes. After signing in, you can access the dashboard to create your workflow.
After accessing your Pabbly Connect dashboard, the next step is to create a new workflow. Click on the ‘Create Workflow’ button and name your workflow to reflect your objective, such as ‘Enroll Students in ThriveCart Learn+ on Instamojo Payments’. using Pabbly Connect
  • Select the folder to save your workflow.
  • Click on ‘Create’ to finalize your new workflow.
Your workflow will consist of two main parts: Trigger and Action. The Trigger will be set to Instamojo, while the Action will be set to ThriveCart Learn+.
3. Setting Up the Trigger with Instamojo in Pabbly Connect
In this step, you will set up the Trigger for your workflow. Search for Instamojo in the Trigger application section and select it. Choose the Trigger event as ‘New Sale’ to initiate the workflow when a new payment is recorded.
To connect Instamojo with Pabbly Connect, you will need to copy the Webhook URL provided. This URL acts as a bridge between Instamojo and Pabbly Connect.
  • Navigate to your Instamojo account and go to the product settings.
  • Paste the copied Webhook URL in the Advanced settings under Webhook URL.
After saving the settings in Instamojo, return to Pabbly Connect, where it will be waiting for a response from the Webhook.
4. Filtering Successful Payments in Pabbly Connect
After receiving the Webhook response, you can set up a filter to ensure that only successful payments trigger the enrollment process. In the Actions section, select ‘Filter by P’ as your action application. using Pabbly Connect
Set the filter condition by selecting the ‘Status’ from the Instamojo response and ensure it equals ‘Credit’. This means that the workflow will only proceed if the payment status indicates a successful transaction.
Click on ‘Save and Send Test Request’ to verify the filter condition. A positive response indicates that the filter is set up correctly.
With the filter in place, you can now set up the final action to enroll the student in ThriveCart Learn+.
5. Enrolling Students in ThriveCart Learn+ Using Pabbly Connect
The last step involves enrolling a new student in your ThriveCart Learn+ course. Search for ThriveCart Learn+ in the action application section and select it. Choose the action event as ‘Create New Student’.
To connect ThriveCart Learn+ with Pabbly Connect, you will need an API token. This token is generated from your ThriveCart Learn+ settings under API and Webhooks section.
Create a new API key and copy it. Paste the API key into Pabbly Connect to establish the connection.
Fill in the required details for the new student using the mapped data from the Instamojo response. After setting everything up, click on ‘Save and Send Test Request’ to finalize the enrollment. You should receive a positive response confirming the successful enrollment.
In this tutorial, we explored how to automate user enrollment in ThriveCart Learn+ using Instamojo Payments through Pabbly Connect. By following these steps, you can save time and enhance the customer experience with seamless integration.
