Learn how to seamlessly enroll users from Instagram Lead Ads to Zenler courses using Pabbly Connect in this step-by-step tutorial. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
To start integrating Instagram Lead Ads and Zenler, you first need to access Pabbly Connect. Visit the Pabbly Connect landing page and sign in with your credentials. If you are a new user, you can sign up for free and get access to many tasks every month.
After signing in, navigate to your dashboard. Here, you will find various applications offered by Pabbly. Click on the option for Pabbly Connect to begin creating your workflow for enrolling users from Instagram Lead Ads.
Once you are in Pabbly Connect, the next step is to create a workflow. Click on the ‘Create Workflow’ button. You will be prompted to name your workflow, such as ‘Enroll User from Instagram Lead Ads’. Choose a folder to save it in, like ‘Automations’, and click on Create.
- Name your workflow appropriately to reflect its purpose.
- Select a folder like ‘Automations’ for better organization.
- Click on Create to proceed to the workflow window.
In the workflow window, you will set up the trigger and action. The trigger represents the event that starts the workflow, while the action is what happens as a result. For this integration, you will set Instagram Lead Ads as the trigger.
3. Setting Up the Trigger from Instagram Lead Ads
In Pabbly Connect, select Instagram Lead Ads as your trigger application. For the trigger event, choose ‘New Lead Instant’. This means that every time a new lead is generated from your Instagram ad, the workflow will be activated.
Next, you need to connect your Instagram account. If you have already connected it, you can select the existing connection. If not, click on ‘Add a New Connection’. After selecting your account, click on Continue. You will then choose the specific page and lead form associated with your Instagram Lead Ads.
- Select the correct Facebook page linked to your Instagram account.
- Choose the lead form that corresponds to your ad campaign.
- Save and send a test request to ensure everything is set up correctly.
After sending the test request, you need to do a test submission through the Meta for Developers tool to capture the webhook response. This step is crucial to ensure that your setup is working properly.
4. Enrolling Users in Zenler
After successfully capturing the lead details, the next action in your Pabbly Connect workflow is to enroll the user in Zenler. Select Zenler as your action application and choose ‘Enroll User to a Course’ as the action event.
Connect your Zenler account by adding a new connection. You will need to enter your Zenler API key and school name. Once connected, select the course where you want to enroll the leads. This is typically the free course you are offering.
Enter your Zenler API key and school name correctly. Select the course ID and course plan ID for enrollment. Map the lead’s email, first name, and last name from the trigger response.
After mapping all necessary details, click on Save and send test request. This will confirm that the user has been successfully enrolled in the course.
To ensure that everything works seamlessly, conduct a test by submitting a new lead through your Instagram Lead Ads. Check the response in Pabbly Connect to confirm that it captures the lead details correctly. Then, verify in Zenler that the user has been enrolled in the course as intended.
After testing, you can review the enrollment in your Zenler account. You should see the new lead listed as a student in your course. Additionally, Zenler will automatically send an email to the enrolled user with their login details.
Confirm that the lead details appear correctly in Pabbly Connect. Check Zenler for successful enrollment of the new user. Ensure that the email with login details is sent to the user.
With these steps completed, your integration using Pabbly Connect is fully functional, allowing you to automate the enrollment of leads from Instagram Lead Ads into your Zenler courses.
This tutorial demonstrates how to use Pabbly Connect to automate the enrollment of users from Instagram Lead Ads into Zenler courses. By following these steps, you can streamline your lead nurturing process effectively.
