Learn how to automate user enrollment in Thinkific through Cashfree Payment with Pabbly Connect. Follow this step-by-step tutorial for seamless integration. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
To start the integration process, first access Pabbly Connect by visiting its official website. If you’re a new user, you can sign up for free and enjoy 100 tasks monthly. Existing users can log in directly to their accounts.
Once logged in, you will see all the Pabbly applications available. Click on the Pabbly Connect icon to access the dashboard. Here, you can create a workflow that connects Cashfree and Thinkific for seamless user enrollment.
In the Pabbly Connect dashboard, click on the ‘Create Workflow’ button located at the top right corner. A dialog box will prompt you to enter a name for your workflow. Enter ‘Enroll Thinkific User on Cashfree Payment’ and select the folder where you want to save this workflow.
  • Choose a specific folder for organization.
Click the ‘Create’ button to finalize your workflow setup. You will now see two windows—Trigger and Action. The Trigger captures the event from Cashfree, while the Action will enroll users in Thinkific.
3. Setting Up the Trigger with Cashfree
For the Trigger application, select Cashfree. The event you want to capture is ‘Payment via Form’. This will allow Pabbly Connect to respond whenever a payment is made through your Cashfree payment form.
After selecting the trigger event, Pabbly Connect will provide you with a unique webhook URL. Copy this URL and navigate to your Cashfree account. Under the ‘Developers’ section, select ‘Webhooks’ and add this webhook URL to the payment form settings.
4. Testing the Connection Between Cashfree and Pabbly Connect
After adding the webhook URL in Cashfree, perform a test payment using the payment form you created. This step is crucial to ensure that the connection between Cashfree and Pabbly Connect is successful. Once the payment is processed, return to your Pabbly Connect dashboard.
  • Ensure you have a test payment ready to go.
  • Check for a successful response in Pabbly Connect.
If the payment response is captured successfully, you can proceed to set up the next action step, which is to filter the payment details based on the course.
5. Enrolling Users in Thinkific
Now that the connection is established, it’s time to enroll users in Thinkific. For this, select Thinkific as the Action application and choose ‘Create User’ as the action event. You will need to connect your Thinkific account by providing the subdomain from your Thinkific URL.
Once connected, map the user data from the Cashfree response, including the first name, last name, and email address. For the password, create a simple password for the new user. After setting up the user details, click on the ‘Save and Send Test Request’ button to finalize user creation.
Finally, to enroll this user in a specific course, add another action step and choose ‘Enroll User’ in Thinkific. Map the user ID from the previous step and select the course you want to enroll them in. This completes the automation process using Pabbly Connect.
By following this tutorial, you can effectively automate the enrollment of Thinkific users through Cashfree payments using Pabbly Connect. This integration not only saves time but also enhances the user experience by allowing students to access courses instantly after payment.
