Learn to integrate ThriveCart with VBOUT using Pabbly Connect for automatic contact creation upon purchase. Step-by-step tutorial included. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
To create a VBOUT contact for ThriveCart purchases, we first need to access Pabbly Connect. Start by navigating to the Pabbly website and selecting the option to sign in or sign up for free if you are a new user.
Once logged in, you will be directed to the dashboard where you can create workflows. Click on the ‘Create Workflow’ button in the top right corner to begin setting up your integration.
After clicking on ‘Create Workflow’, a dialog box will prompt you to name your workflow. Enter a suitable name, such as ‘Create VBOUT Contacts for ThriveCart Purchase’. Then, click on ‘Create’ to proceed.
  • Select ThriveCart as the trigger application.
  • Choose ‘Product Purchase’ as the trigger event.
  • Connect your ThriveCart account using the API key.
By following these steps, you establish the trigger that will monitor new purchases in ThriveCart. This sets the foundation for our automation process using Pabbly Connect.
3. Connecting ThriveCart to Pabbly Connect
To connect ThriveCart, click on the ‘Connect’ button and then select ‘Add New Connection’. You will need to enter your API token from your ThriveCart account. using Pabbly Connect
To obtain the API token, go to your ThriveCart account, navigate to the ‘Settings’ section, and select ‘API and Webhooks’. Generate a new API key by clicking on the ‘Generate Key’ button, then copy and paste this key back into Pabbly Connect.
4. Testing the Integration with a Sample Purchase
After successfully connecting ThriveCart, you need to test the integration. Select the product you want to track, for example, ‘Advanced PHP Course’, and ensure it is in test mode. using Pabbly Connect
  • Click on ‘Save and Send Test Request’ in Pabbly Connect.
  • Make a test purchase using the provided checkout link.
  • Enter dummy user details for the purchase.
Once the purchase is made, Pabbly Connect will receive the response containing the purchase details, confirming that the integration is functioning properly.
5. Creating a New Contact in VBOUT
With the purchase details received, it’s time to create a new contact in VBOUT. Select VBOUT as the action application and choose ‘Add Contacts to List’ as the action event. using Pabbly Connect
Connect your VBOUT account by entering the API user key found under the ‘API Integrations’ section in your VBOUT account settings. After connecting, select the list where you want to add the new contact and map the necessary fields like email, first name, and last name using the data retrieved from ThriveCart.
Once all fields are mapped correctly, click on ‘Save and Send Test Request’ to finalize the process. You should receive a confirmation that the contact has been successfully created in VBOUT.
In this tutorial, we demonstrated how to integrate ThriveCart with VBOUT using Pabbly Connect. By following the outlined steps, you can automate the creation of contacts in VBOUT whenever a purchase is made in ThriveCart. This seamless integration enhances your marketing efforts and ensures that customer data is managed efficiently.
