Learn how to integrate ThriveCart Learn+ with GrooveSell Purchase using Pabbly Connect to automate student creation seamlessly. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
To create a ThriveCart Learn+ student on GrooveSell purchase, start by accessing Pabbly Connect. You can do this by typing ‘Pabbly.com/connect’ in your browser. Here, you will find options to sign in or sign up for free.
If you’re an existing user, simply sign in. New users can click the ‘Sign Up for Free’ button to create an account, which allows for 100 tasks monthly at no cost. Once logged in, you can access your dashboard and begin creating your workflow.
After logging into Pabbly Connect, navigate to the dashboard and click on the ‘Create Workflow’ button located in the top right corner. A dialog box will prompt you to name your workflow. For this integration, name it ‘Create ThriveCart Learn+ Student on GrooveSell Purchase’.
- Select a folder to save your workflow, such as ‘GrooveSell to Learn Dash Automation’.
Now, you will be taken to a window where you can configure the trigger and action for your workflow. Remember, triggers initiate the workflow when an event occurs, while actions define what happens next.
In this step, you will set the trigger application to GrooveSell. Search for GrooveSell in the trigger window and select it. The trigger event will be ‘Product Purchased’, which activates the workflow whenever someone buys a course. using Pabbly Connect
Next, set the action application to ThriveCart Learn+. Choose the action event ‘Create New Student’. This configuration means that every time a product is purchased through GrooveSell, a new student will be created in ThriveCart Learn+.
4. Connecting GrooveSell to Pabbly Connect
To establish the connection, you will need to use a webhook URL provided by Pabbly Connect. This URL acts as a bridge between GrooveSell and Pabbly Connect. Copy the webhook URL from the trigger setup in Pabbly Connect.
Now, log into your GrooveSell account, navigate to the product funnels, and select the course you want to connect. Click on ‘Manage Product Funnel’, then ‘Edit Product’. Go to the Fulfillment tab and paste the copied webhook URL into the Webhook section. Click on ‘Save’ to apply the changes.
5. Testing the Integration and Creating a Student
With the webhook successfully set up, it’s time to test the integration. Head back to your GrooveSell checkout page and make a test purchase of the course. Fill in the required details and complete the purchase using dummy payment information.
After completing the purchase, go back to Pabbly Connect. You should see a response indicating that the purchase data has been captured. Now, to create a student in ThriveCart Learn+, connect your ThriveCart account by entering the API key from your ThriveCart profile settings into Pabbly Connect.
Next, map the necessary fields such as email and course ID, ensuring that each new purchase creates a student with the correct details. Click on ‘Save and Send’ to finalize the process. If successful, a new student should appear in your ThriveCart Learn+ account, confirming the integration works flawlessly.
In this tutorial, we demonstrated how to create a ThriveCart Learn+ student on GrooveSell purchase using Pabbly Connect. This integration automates the student creation process, ensuring seamless data transfer between the two platforms.
