Learn how to automate the creation of ThriveCart Learn+ students upon GrooveSell purchases using Pabbly Connect in this detailed tutorial. This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
To create a ThriveCart Learn+ student on GrooveSell purchase, first access Pabbly Connect. This platform is essential for automating the integration process between GrooveSell and ThriveCart Learn+.
Visit the Pabbly Connect website by typing in ‘Pabbly.com/connect’ in your browser. You will find options to sign in or sign up. New users can sign up for free and get 100 tasks monthly. Existing users can simply sign in to access their dashboard.
Once logged into Pabbly Connect, you need to create a new workflow. Click on the ‘Create Workflow’ button located in the upper right corner of the dashboard. Name your workflow something descriptive, like ‘Create ThriveCart Learn+ Student on GrooveSell Purchase’.
  • Click on ‘Create’.
  • Select GrooveSell as the trigger application.
  • Set the trigger event to ‘Product Purchased’.
This setup ensures that whenever a product is purchased in GrooveSell, the workflow will be triggered. The next step will be to configure the action in ThriveCart Learn+.
3. Configuring the Trigger in Pabbly Connect
In this step, you’ll configure the GrooveSell trigger in Pabbly Connect. After selecting GrooveSell, a webhook URL will be generated. This URL acts as a bridge between GrooveSell and Pabbly Connect.
Copy the webhook URL and navigate to your GrooveSell account. Go to the product funnels and select the course you want to connect. In the fulfillment section, paste the webhook URL into the webhook field and save your changes.
4. Setting Up the Action for ThriveCart Learn+
Now, set up the action in Pabbly Connect to create a new student in ThriveCart Learn+. Choose ThriveCart Learn+ as your action application and select the action event as ‘Create New Student’.
Next, you will need to connect your ThriveCart Learn+ account by entering your API key. To find the API key, go to your ThriveCart Learn+ profile settings. After obtaining the key, paste it into Pabbly Connect.
  • Map the necessary fields such as the student’s email and course ID.
  • Ensure the mapping is dynamic to accommodate new data with each purchase.
Once all details are mapped, click ‘Save and Send Test Request’ to verify the integration. If successful, a new student will be created in your ThriveCart Learn+ account.
5. Testing the Integration
To finalize the setup, test the integration by making a purchase on GrooveSell. Use a test product like the ‘Java Course for Beginners’ to simulate a transaction. After completing the purchase, check the response in Pabbly Connect.
If the integration is successful, you should see the purchase details captured in Pabbly Connect. This confirms that the student has been successfully created in ThriveCart Learn+ based on the GrooveSell purchase.
Now, you can be assured that every time a user purchases a course, they will automatically be created as a student in ThriveCart Learn+ through the seamless automation provided by Pabbly Connect.
In this tutorial, we demonstrated how to create a ThriveCart Learn+ student on GrooveSell purchase using Pabbly Connect. This integration streamlines the process, ensuring students are automatically enrolled upon purchase, enhancing efficiency and user experience.
