Learn how to integrate ConvertBox with ThriveCart Learn+ using Pabbly Connect for seamless student creation on form submission. Follow this detailed tutorial for step-by-step guidance.
To create a ThriveCart Learn+ student on ConvertBox form submission, we will use Pabbly Connect. Start by visiting the Pabbly Connect website and signing in or signing up for a free account. This platform allows you to automate workflows without any coding knowledge.
Once logged in, navigate to the dashboard where you can create a new workflow. Click on the ‘Create Workflow’ button and name it according to the task, such as ‘Create ThriveCart Learn+ Student on ConvertBox Form Submission’. This sets the stage for your integration process.
2. Configuring the Trigger with ConvertBox
The next step involves setting up the trigger in Pabbly Connect. Select ConvertBox as your trigger application and choose the event as ‘New Lead Submission’. This event will initiate the workflow whenever a new form is submitted.
  • Search for ConvertBox in the Trigger section.
  • Select the trigger event as New Lead Submission.
After copying the webhook URL, log into your ConvertBox account, edit the form you want to connect, and navigate to the form settings. Under actions, select ‘Add Integration’ and choose Webhooks. Paste the copied URL and save your changes to complete the trigger setup.
3. Testing the Trigger Setup in Pabbly Connect
Now that the trigger is configured, it’s time to test it. Go back to Pabbly Connect and make a new submission on your ConvertBox form. Fill in the required fields, such as first name, last name, and email address.
Once you submit the form, return to Pabbly Connect. You should see a response indicating that the webhook has received the data from ConvertBox. This confirms that the trigger is functioning correctly and is ready to proceed to the next step.
4. Setting Up the Action with ThriveCart Learn+
The next phase involves setting the action to create a new student in ThriveCart Learn+. In your Pabbly Connect workflow, select ThriveCart Learn+ as the action application and choose the action event as ‘Create New Student’.
  • Connect your ThriveCart Learn+ account by providing the API token.
  • Map the email address and course ID from the ConvertBox response.
  • Fill in the student’s first and last name using the mapped data.
Once all necessary fields are filled, click on the ‘Send Test’ button in Pabbly Connect. This action will create a new student in your ThriveCart Learn+ account based on the submitted data from ConvertBox.
5. Verifying the Integration and Final Steps
After setting up the action, it’s essential to verify that the integration works seamlessly. Go to your ThriveCart Learn+ account and check the students’ list to confirm that the new student has been created successfully.
To ensure everything functions correctly, you can perform another test by submitting the ConvertBox form again with different data. Check back in Pabbly Connect and ThriveCart Learn+ to see if the new student is added. This confirms that your integration is functioning as expected.
In conclusion, using Pabbly Connect, you can automate the process of creating ThriveCart Learn+ students from ConvertBox form submissions efficiently. This integration streamlines your workflow and saves time by eliminating manual data entry.
