Learn how to integrate Typeform and Systeme.io using Pabbly Connect to automate the creation of contacts on form submissions. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
To create Systeme.io contacts on Typeform submission, you first need to access Pabbly Connect. This powerful automation tool allows you to connect different applications seamlessly. Begin by signing in to your existing Pabbly account or create a new one if you are a new user.
Once logged in, navigate to the applications page and select Pabbly Connect. From here, you can create a new workflow by clicking on the ‘Create Workflow’ button. This is where you will set up the integration between Typeform and Systeme.io.
2. Setting Up the Workflow in Pabbly Connect
In this section, you’ll set up the workflow to automate the process. Click on the ‘Create Workflow’ button and name your workflow, for example, ‘Create Systeme.io Contacts on Typeform Submission.’ Organize it into a folder for better management. using Pabbly Connect
- Name the workflow appropriately.
- Select the folder where you want to save it.
After creating the workflow, you will see options for setting up the trigger and action. The trigger will be Typeform, and the action will be Systeme.io. This setup will allow you to create a contact in Systeme.io whenever a new Typeform submission is received.
3. Configuring Trigger and Action in Pabbly Connect
To configure the trigger, select Typeform as the application and choose the ‘New Entry’ trigger event. This ensures that the workflow activates upon receiving a new form submission. Next, set the action application to Systeme.io and select the ‘Create New Contact’ action event.
Now, establish a connection between Typeform and Pabbly Connect. Click on the ‘Connect’ button and authorize the connection by accepting the permissions. This step is crucial for enabling data transfer between Typeform and Pabbly Connect.
- Select your Typeform form from the dropdown.
- Click on ‘Save and Send Test Request’ to capture the first submission.
- Fill out the Typeform to test the integration.
After submitting the form, you will receive a response in Pabbly Connect, confirming that the data has been captured successfully. This response will include all the details submitted through Typeform.
4. Creating Contacts in Systeme.io
With the data captured from Typeform, the next step is to create a contact in Systeme.io. To do this, you must establish a connection between Systeme.io and Pabbly Connect. Click on the ‘Connect’ button and enter your API key from your Systeme.io account.
To find your API key, navigate to your Systeme.io profile settings and create a new API key. Once you have copied the key, paste it into Pabbly Connect and save the connection. This allows Pabbly Connect to send data to Systeme.io for contact creation.
Map the fields from the Typeform response to the corresponding fields in Systeme.io. Ensure that the country field is correctly filled with the country code for India. Click on ‘Save and Send Test Request’ to finalize the setup.
Once you receive a positive response, it indicates that the contact has been successfully created in your Systeme.io account. This shows that your integration is working correctly and that every Typeform submission will result in a new contact being created.
5. Conclusion
By following these steps, you can effectively automate the creation of Systeme.io contacts on Typeform submissions using Pabbly Connect. This integration streamlines your workflow and ensures that you never miss capturing valuable contact information.
Utilizing Pabbly Connect allows you to enhance your data management processes, making it easier to handle customer interactions efficiently. Start automating your workflows today for better productivity!
