Learn how to automate subscriber creation in Flodesk from Thinkific enrollment using Pabbly Connect. Follow our step-by-step tutorial for seamless integration! Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
To create a subscriber in Flodesk from Thinkific enrollment, you need to access Pabbly Connect. Begin by signing in to your existing account or create a new one if you’re a first-time user. Pabbly Connect offers 100 free tasks each month, making it easy to get started.
Once logged in, navigate to the dashboard where you can create new workflows. Click on the ‘Create Workflow’ button located in the top right corner. Name your workflow as ‘Create Subscriber in Flodesk from Thinkific Enrollment’ and save it in your desired folder.
2. Setting Up Trigger and Action in Pabbly Connect
In this step, you will set the trigger and action for your workflow using Pabbly Connect. The trigger application is Thinkific, and the event is set to ‘Enrollment Created’. This means that every time a new enrollment occurs, your workflow will be triggered.
Next, you will set the action application to Flodesk, with the action event as ‘Create or Update Subscriber’. This setup ensures that whenever a user enrolls in Thinkific, they will automatically be created as a subscriber in Flodesk.
- Select Thinkific as the trigger application.
- Choose ‘Enrollment Created’ as the trigger event.
- Set Flodesk as the action application.
- Select ‘Create or Update Subscriber’ as the action event.
With the trigger and action set, you are ready to establish a connection between Thinkific and Pabbly Connect. This connection is crucial for automating the subscriber creation process.
3. Connecting Thinkific to Pabbly Connect
To connect Thinkific with Pabbly Connect, you will need to set up a webhook. A webhook URL is provided by Pabbly Connect, which acts as a bridge between the two applications. Copy the webhook URL and head to your Thinkific account.
In Thinkific, go to the settings and find the ‘Webhooks’ section. Click on the ‘New Webhook’ button, paste the webhook URL, and select the model as ‘Enrollment’ with the topic as ‘Enrollment Created’. Save the webhook settings to complete the connection.
- Navigate to Thinkific settings and select ‘Webhooks’.
- Click on ‘New Webhook’ and paste the webhook URL from Pabbly Connect.
- Choose ‘Enrollment’ as the model and ‘Enrollment Created’ as the topic.
- Save the webhook settings.
After saving, return to Pabbly Connect where it will now be waiting for a webhook response. This indicates that the connection has been successfully established.
4. Testing the Integration with Enrollment
Now that the connection is established, it’s time to test the integration using Pabbly Connect. To do this, create a new enrollment in Thinkific. Open the course page in an incognito window and fill out the enrollment form with the necessary details such as first name, last name, email, and password.
Once the enrollment is completed, return to Pabbly Connect to see if the webhook has captured the enrollment data. You should see a positive response with all the details of the new enrollment, including first name, last name, email, and course name.
Open the course in an incognito window. Fill in the enrollment details and submit. Check Pabbly Connect for the webhook response.
With the enrollment data captured, you are now ready to create a subscriber in Flodesk using the information received from Thinkific.
5. Creating a Subscriber in Flodesk
To create a subscriber in Flodesk, you will need to connect your Flodesk account with Pabbly Connect. Click on the connect button, and you will be prompted to allow access to your Flodesk account. Once authorized, you can proceed to map the fields from the Thinkific enrollment data to the Flodesk subscriber fields.
In the mapping section, select the email, first name, and last name fields from the Thinkific response. This mapping ensures that every new enrollment creates a corresponding subscriber in Flodesk. After mapping, click on the ‘Save and Send Test Request’ button to finalize the process. You should receive a confirmation that the subscriber was successfully created in Flodesk.
Connect your Flodesk account to Pabbly Connect. Map the fields from Thinkific to Flodesk. Click ‘Save and Send Test Request’ to create the subscriber.
After refreshing your Flodesk account, you should see the new subscriber added successfully. This confirms that the integration between Thinkific and Flodesk through Pabbly Connect is now fully operational.
In this tutorial, we successfully demonstrated how to create subscribers in Flodesk from Thinkific enrollment using Pabbly Connect. By following the steps outlined, you can automate the process of adding new subscribers, enhancing your marketing efforts seamlessly.
