Learn how to automate the creation of subscribers for LinkedIn Legion Ads leads using Pabbly Connect. Step-by-step guide with detailed instructions. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
To automate the creation of subscribers for LinkedIn Legion Ads leads, you need to access Pabbly Connect. Start by visiting the Pabbly Connect website by typing ‘Pabbly.com/connect’ in your browser. Once on the landing page, you’ll see options to sign in or sign up.
If you are a new user, click on ‘Sign Up for Free’ to get 100 tasks free monthly. Existing users can simply sign in. After logging in, you will be directed to the Pabbly Connect dashboard where you can manage your workflows.
Once in the Pabbly Connect dashboard, the next step is to create a new workflow. Click on ‘Create Workflow’ and name it something descriptive, like ‘Create Subscriber for LinkedIn Legion Ads Leads’. Select the folder where you want to save this workflow and click ‘Create’. using Pabbly Connect
  • Click on ‘Create Workflow’
  • Name your workflow
  • Select the appropriate folder
  • Click ‘Create’
After creating the workflow, you will see two boxes labeled ‘Trigger’ and ‘Action’. The trigger is the event that starts the automation, and in this case, it will be LinkedIn Legion Ads leads.
3. Setting Up the Trigger with LinkedIn Legion Ads
In the trigger application box, select ‘LinkedIn Lead Gen Forms’ and then choose the trigger event as ‘New Lead Form Response’. Click on ‘Connect’ to set up the connection. If you don’t have an existing connection, click on ‘Add New Connection’ and authorize Pabbly Connect to access your LinkedIn account. using Pabbly Connect
After connecting, select the LinkedIn account and the specific lead form you will be using. This form will be monitored for new leads, and once a lead is generated, it will trigger the workflow.
4. Configuring the Action to Create Subscribers in Kit
Now, move to the action application and select ‘Kit’ as the action app. Choose the action event as ‘Tag Subscriber’. Similar to the trigger setup, click on ‘Connect’ and enter your API key and API secret from your Kit account to establish the connection. using Pabbly Connect
  • Select ‘Kit’ as the action application
  • Choose ‘Tag Subscriber’ as the action event
  • Connect using your API key and secret
After successfully connecting to Kit, you will need to fill in the required fields such as tag ID, email, and first name. Use the mapping feature to dynamically pull in data from the LinkedIn lead form responses.
After configuring both the trigger and action, it’s time to test the integration. Submit a test lead through your LinkedIn form. Go back to Pabbly Connect and click on ‘Save and Send Test Request’ to check if the data flows correctly from LinkedIn to Kit.
Upon successful submission, check your Kit account to confirm that the subscriber has been created. You should see the new subscriber with the details entered in the LinkedIn form, confirming that the integration via Pabbly Connect is working seamlessly.
In summary, this tutorial showcased how to automate the creation of subscribers in Kit from LinkedIn Legion Ads leads using Pabbly Connect. By following the steps outlined, you can efficiently manage your leads and enhance your marketing efforts.
