Learn how to create a subscriber in MailerLite group from WooCommerce orders using Pabbly Connect. Step-by-step tutorial to automate your email marketing. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
Accessing Pabbly Connect for WooCommerce and MailerLite Integration
To create a subscriber in MailerLite group on WooCommerce order, you need to access Pabbly Connect. Start by opening a web browser and searching for Pabbly Connect’s official website. If you already have an account, simply sign in; otherwise, click on ‘Sign Up for Free’ to create a new account.
Once logged in, you will be directed to the dashboard. Here, you can create a new workflow by clicking on the ‘Create Workflow’ button. Name your workflow according to your objective, such as ‘Create Subscriber in MailerLite Group on WooCommerce Order’. This is where you will set up the integration to automate the process of adding subscribers from WooCommerce orders to MailerLite.
Setting Up Trigger in Pabbly Connect for WooCommerce Orders
The next step is to set up the trigger in Pabbly Connect. In your newly created workflow, you will find two sections: Trigger and Action. For the trigger application, select WooCommerce and choose the event ‘New Order Created’. This event will initiate the workflow every time a new order is placed in your WooCommerce store.
After selecting the trigger event, you will need to connect WooCommerce with Pabbly Connect. This is done by copying the webhook URL provided by Pabbly Connect. Navigate to your WooCommerce settings in WordPress, go to the Advanced settings, and find the Webhooks section. Here, you will create a new webhook by clicking on the ‘Add Webhook’ button and filling in the necessary details:
  • Name: MailerLite
  • Status: Active
  • Topic: Order Created
  • Delivery URL: Paste the copied webhook URL here
After saving the webhook, return to Pabbly Connect and click on the ‘Recapture Webhook Response’ button. This will allow you to receive the details of the new order once it is created.
Creating Subscriber in MailerLite Using Pabbly Connect
Now that the trigger is set up, it’s time to create the subscriber in MailerLite. In Pabbly Connect, you will set the action application as MailerLite and choose the action event ‘Create or Update Subscriber’. After selecting this event, you will need to connect MailerLite with Pabbly Connect by entering your API token.
To obtain the API token, log in to your MailerLite account, navigate to the Integrations section, and select API. Generate a new token by clicking on the ‘Generate New Token’ button, giving it a name like ‘WooCommerce Order’, and accepting the terms and conditions. Copy the generated token and paste it into Pabbly Connect to establish the connection.
Once connected, you will need to map the subscriber details from the WooCommerce order response. This includes the subscriber’s email, first name, last name, city, phone number, state, and ZIP code. By mapping these fields, you ensure that the subscriber information is dynamically updated with each new order placed in WooCommerce.
Testing and Confirming the Integration with Pabbly Connect
With everything set up, it’s time to test your integration. Create a new order in your WooCommerce store by adding a product to the cart and proceeding to checkout. Fill in the customer details, including a valid email address, and place the order.
Return to Pabbly Connect and check for a response from the webhook. You should see the details of the new order, confirming that the integration is working correctly. If the response is successful, the subscriber will be created in your specified MailerLite group.
To verify, log in to your MailerLite account, navigate to the subscribers section, and check the group you specified. You should see the new subscriber listed with all the details accurately captured from the WooCommerce order.
In this tutorial, we demonstrated how to use Pabbly Connect to create a subscriber in MailerLite group from WooCommerce orders. By automating this process, you can streamline your email marketing efforts and enhance customer engagement without manual intervention. This setup not only saves time but also ensures that every new customer is accurately added to your email list for targeted campaigns.
