Learn how to create a subscriber in Flodesk from Thinkific enrollment using Pabbly Connect. Step-by-step guide with detailed instructions and UI elements. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
To create a subscriber in Flodesk from Thinkific enrollment, start by accessing Pabbly Connect. This powerful automation tool allows you to connect various applications seamlessly. If you are an existing user, simply sign in; new users can sign up for free and receive 100 tasks each month.
Once signed in, navigate to the dashboard. Here, you will find the option to create a new workflow. Click on the ‘Create Workflow’ button located in the top right corner. Name your workflow something descriptive, like ‘Create Subscriber in Flodesk from Thinkific Enrollment,’ and save it in a relevant folder.
2. Setting Up Trigger and Action in Pabbly Connect
In this step, you will set up the trigger and action for your workflow in Pabbly Connect. The trigger application will be Thinkific, and the action application will be Flodesk. For the trigger event, select ‘Enrollment Created,’ which will activate whenever a new enrollment occurs in your Thinkific account.
- Trigger Application: Thinkific
- Trigger Event: Enrollment Created
- Action Application: Flodesk
- Action Event: Create or Update Subscriber
After selecting the trigger and action, you will need to establish a connection between Thinkific and Pabbly Connect. A webhook URL will be provided, which you will use to connect your Thinkific account. This URL acts as a bridge for data transfer.
3. Creating a Webhook in Thinkific
To create a webhook in Thinkific, go to your Thinkific account settings and navigate to the Webhooks section. Click on the ‘New Webhook’ button and paste the webhook URL from Pabbly Connect into the target URL field. This step is crucial as it enables Thinkific to send enrollment data to Pabbly Connect.
When setting up the webhook, ensure you select the model for enrollment and specify the enrollment topic as ‘Enrollment Created.’ After filling in these details, click on the ‘Save’ button to create the webhook successfully.
Now, return to Pabbly Connect where it will be waiting for a webhook response. You will need to test the webhook by enrolling a user in one of your Thinkific courses to capture the data.
4. Testing the Webhook and Mapping Data
To test the webhook, navigate back to your Thinkific account and enroll a user in a course, such as the ‘Core PHP Programming’ course. Fill in the required details like first name, last name, email, password, and phone number, then click on ‘Enroll for Free.’ This action will trigger the webhook in Pabbly Connect.
Once the enrollment is successful, Pabbly Connect will capture the response. You should see a positive response indicating that the enrollment data has been received. This data includes the user’s first name, last name, email, and course name.
- User First Name
- User Last Name
- User Email
- Course Name
This successful capture means that the automation setup is working correctly. You can now proceed to map this data to create a subscriber in Flodesk.
5. Creating a Subscriber in Flodesk
Now that you have successfully captured the enrollment data in Pabbly Connect, the next step is to create a subscriber in Flodesk. Click on the ‘Connect with Flodesk’ button to establish a connection. You will need to authorize Pabbly Connect to access your Flodesk account.
Once connected, you will need to map the captured data to the corresponding fields in Flodesk. For instance, select the email field and map it to the email captured from the Thinkific enrollment. Similarly, map the first name and last name fields using the data received.
After mapping all necessary fields, click on the ‘Save and Send Test Request’ button. If successful, you will receive a confirmation that a new subscriber has been created in your Flodesk account. Refresh your Flodesk account to see the new subscriber listed under ‘All Subscribers.’ This completes the integration process using Pabbly Connect.
In this tutorial, we explored how to create a subscriber in Flodesk from Thinkific enrollment using Pabbly Connect. By following the steps outlined, you can automate the process of adding new subscribers based on course enrollments. This integration not only saves time but also enhances your marketing efforts.
