Learn how to automatically add Mautic contacts as subscribers in Sendy using Pabbly Connect. Follow this step-by-step tutorial for seamless integration. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
1. Introduction to Pabbly Connect Integration
Pabbly Connect is an integration and automation platform that allows you to connect different applications seamlessly. In this tutorial, we will use Pabbly Connect to automate the process of adding Mautic contacts as subscribers in Sendy. This integration ensures that every new contact created in Mautic is automatically added to your Sendy subscriber list.
To begin, make sure you have accounts set up in both Mautic and Sendy. You will also need to create a free account in Pabbly Connect if you haven’t done so already. Once logged in, you can access the dashboard to start creating your workflow.
To create a workflow in Pabbly Connect, click on the blue button labeled ‘Create Workflow’. You should give your workflow a descriptive name, such as ‘Add Mautic Contacts to Sendy as Subscribers’. After naming your workflow, click on the ‘Create’ button to proceed.
Now, you will see two sections labeled ‘Trigger’ and ‘Action’. The trigger indicates the event that starts the automation, while the action is what happens as a result. In this case, select Mautic as the trigger application and choose the event ‘New Form Entry’. This setup means that whenever a new contact is created in Mautic, it will trigger the action to add that contact to Sendy.
3. Setting Up Mautic with Pabbly Connect
Once you have selected Mautic as your trigger, Pabbly Connect will provide you with a webhook URL. You need to copy this URL and set it up in your Mautic account. To do this, go to Mautic’s dashboard, click on the settings gear icon, and navigate to the ‘Webhooks’ section.
Create a new webhook by pasting the copied URL and giving it a name, such as ‘Pabbly Connect Webhook’. Make sure to select the event ‘Form Submit’. After saving the webhook, you will need to test it by creating a new contact in Mautic to ensure that the data is captured correctly by Pabbly Connect.
4. Configuring Sendy in Pabbly Connect
With Mautic set up, it’s time to configure Sendy in Pabbly Connect. Select Sendy as your action application and connect it by clicking on ‘Add New Connection’. You will need to provide your Sendy API key and installation URL. You can find these details in your Sendy account settings.
After entering the API key and URL, you will be prompted to enter the List ID where the new subscribers will be added. You can find the List ID in your Sendy dashboard under the list settings. Once you’ve entered the List ID, you can map the fields from Mautic to Sendy, such as the subscriber’s name and email address.
- Enter the List ID from Sendy.
- Map the fields for name and email from Mautic.
- Click on ‘Save and Send Test Request’ to finalize the setup.
After clicking save, you should see a confirmation that the subscriber has been created in Sendy. This confirms that your integration is working correctly.
5. Conclusion
Using Pabbly Connect to integrate Mautic and Sendy allows for seamless automation of your contact management. By following the steps outlined in this tutorial, you can ensure that every new Mautic contact is automatically added as a subscriber in Sendy, saving you time and effort.
With this setup, you can focus on your marketing strategies while Pabbly Connect handles the integration in the background. Start automating your workflow today for enhanced efficiency and better subscriber management.
