Learn how to create a Pinterest pin for your new Shopify product using Pabbly Connect. Follow this step-by-step guide for seamless integration. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
1. Accessing Pabbly Connect for Shopify and Pinterest Integration
To create a Pinterest pin for a new Shopify product, the first step is accessing Pabbly Connect. You can visit Pabbly.com/c/connect in your browser to reach the Pabbly Connect landing page.
If you don’t have an account, click on the ‘Sign up for free’ button. This process takes about two minutes and grants you 100 free tasks every month. If you already have an account, simply sign in to continue.
After signing in, you will see the dashboard of Pabbly Connect. Click on the ‘Create Workflow’ button to start building your integration. Name your workflow something descriptive, like ‘Create Pinterest Pin for New Shopify Product’.
This workflow consists of two main components: the trigger and the action. The trigger indicates when the workflow will start, and the action specifies what will happen. In this case, select Shopify as the trigger application and choose ‘New Product’ as the trigger event.
  • Select ‘Shopify’ as the trigger application.
  • Choose ‘New Product’ as the trigger event.
  • Click on ‘Connect’ to link Shopify with Pabbly Connect.
After setting up the trigger, you will need to connect Shopify to Pabbly Connect using a webhook URL. This URL acts as a bridge between Shopify and Pabbly Connect.
3. Setting Up Webhook in Shopify
To connect Shopify with Pabbly Connect, copy the webhook URL provided in your workflow. Then, go to your Shopify account and navigate to Settings, followed by Notifications.
In the Notifications section, find the Webhooks area and click on the ‘Create Webhook’ button. Select ‘Product Creation’ as the event, set the format to JSON, and paste the copied webhook URL into the URL field. Finally, choose the latest API version and click on ‘Save’ to complete the setup.
  • Select ‘Product Creation’ for the event.
  • Set the format to ‘JSON’.
  • Paste the webhook URL from Pabbly Connect.
Once saved, return to Pabbly Connect, where it will wait for a webhook response from Shopify, indicating that the connection is established successfully.
4. Creating a New Product in Shopify
Next, you need to create a new product in your Shopify account to trigger the workflow. Navigate to the Products section and click on the ‘Add Product’ button. Fill in the required details, such as the product title, description, and image.
For this tutorial, the product title will be ‘Polo T-shirts’, with a description stating ‘All-weather Polo T-shirt with vibrant colors’. Set the price at 350 rupees, and after filling in all the details, click on ‘Save’. This action will trigger the webhook in Pabbly Connect.
Title: Polo T-shirts Description: All-weather Polo T-shirt with vibrant colors Price: 350 rupees
After saving, return to Pabbly Connect where you will see the response containing all product details, including product ID, price, title, and image URL.
5. Creating a Pin in Pinterest Using Pabbly Connect
Now that you have the product details, it’s time to create a pin in Pinterest. In your Pabbly Connect workflow, add a new action by selecting Pinterest as the application and choosing ‘Create Pin’ as the action event.
Connect Pinterest to Pabbly Connect by clicking on ‘Connect’ and authorizing access. Next, you will need to specify which board to add the pin to. Select the board labeled ‘Shopify Products’ from your Pinterest account.
Select the board: Shopify Products Map the image URL from Shopify response. Map the title and description for the pin.
After mapping all the required details, click on ‘Save and Send Test’. If successful, you will see a confirmation response indicating that the pin was created. Refresh your Pinterest account to view the new pin added to your selected board.
Using Pabbly Connect, you can automate the process of creating Pinterest pins for new Shopify products effortlessly. This integration not only saves time but also enhances your product visibility on Pinterest, driving more traffic to your Shopify store.
