Learn how to automate Nuelink collection posts from Google Drive using Pabbly Connect. This step-by-step tutorial covers integration and setup processes. This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
To create Nuelink collection posts from Google Drive, the first step is to access Pabbly Connect. You can do this by visiting the Pabbly Connect website and signing in or signing up for a free account if you don’t have one.
Once you are logged in, you will be directed to the Pabbly Connect dashboard. This is where all the integrations take place, and you will create a new workflow to connect Google Drive with Nuelink. Start by clicking on the ‘Create Workflow’ button to begin setting up your automation.
In this section, you will set up the trigger that initiates the workflow in Pabbly Connect. The trigger application will be Google Drive, specifically set to detect when a new file is uploaded.
  • Select Google Drive as the trigger application.
  • Choose the trigger event ‘New File in Specific Folder’.
  • Connect your Google Drive account to Pabbly Connect by allowing necessary permissions.
After connecting, select the specific folder in Google Drive where you will upload the new files. This setup ensures that every time a file is added to this folder, it will trigger the automation in Pabbly Connect.
3. Uploading Files to Google Drive
Now that the trigger is set up in Pabbly Connect, you can upload the files to Google Drive. The goal is to automate the process of adding a new post to your Nuelink collection whenever a file is uploaded.
To do this, go to your selected folder in Google Drive and click on the ‘New’ button. Then choose ‘File Upload’ and select the desired video or image file. For example, you might upload a video titled ‘Golden Serenity Capturing the Majestic Sunset.mp4’. Once uploaded, this file will be detected by Pabbly Connect and will initiate the next steps of your workflow.
4. Adding a New Post to Nuelink
After uploading the file, the next step is to add a new post to Nuelink using the details captured by Pabbly Connect. This is done by setting up an action step in the workflow.
  • Select Nuelink as the action application.
  • Choose the action event ‘Add Post to Collection’.
  • Connect your Nuelink account to Pabbly Connect.
Next, you will need to map the required fields, such as the post caption and media URL. For the caption, use the title of the uploaded file without the file extension. For the media URL, use the link generated by Google Drive for the uploaded video.
5. Finalizing the Automation Process
Once all the fields are mapped in Pabbly Connect, you can finalize the automation by saving and testing the workflow. This ensures that the data is correctly sent to Nuelink.
After testing, you should see a success response indicating that the new post has been added to your Nuelink collection. You can verify this by refreshing your Nuelink account and checking the collection for the newly added post.
This automation allows you to efficiently manage your social media posts by automatically creating new entries based on your Google Drive uploads. With Pabbly Connect, you can streamline your content creation process and ensure that your posts are timely and organized.
In this tutorial, we explored how to use Pabbly Connect to create Nuelink collection posts from Google Drive. By following the steps outlined, you can automate the process of adding posts based on uploaded files, enhancing your social media management.
