Learn how to create NeoDove leads from LinkedIn leads using Pabbly Connect. This step-by-step guide covers the integration process and automation features. Master proven automation processes with practical implementation examples and strategic recommendations you can apply immediately in your workflow.
1. Accessing Pabbly Connect for LinkedIn Leads Integration
To create NeoDove leads from LinkedIn leads, start by accessing Pabbly Connect. Open your web browser and type in ‘Pabbly.com/connect’. This will take you to the Pabbly Connect homepage where you can either sign in or sign up for free.
If you’re a new user, click on the ‘Sign up for free’ button. As an existing user, simply log in. Once logged in, navigate to the ‘All Applications’ page and click on the Pabbly Connect option to access the dashboard.
The next step is to create a new workflow for integrating LinkedIn leads with NeoDove using Pabbly Connect. In the dashboard, locate the ‘Create Workflow’ button in the top right corner and click it. A dialog box will appear for you to name your workflow.
- Name your workflow as ‘Create NeoDove Leads from LinkedIn Leads’.
- Choose a folder to save your workflow, such as ‘LinkedIn NeoDove Automation’.
After clicking ‘Create’, you will be directed to a window where you can set up the trigger and action for your workflow. This is crucial for automating the lead creation process using Pabbly Connect.
In this step, you will define the trigger event using Pabbly Connect. Search for ‘LinkedIn Leads’ as your trigger application and select ‘New Lead Gen Form Response’ as the trigger event. This will ensure that whenever a new lead is generated on LinkedIn, it triggers the workflow.
Next, you need to set the action application. Search for ‘NeoDove’ as your action application and select ‘Create Lead’ as the action event. This means that every time a new lead is captured from LinkedIn, it will automatically create a lead in NeoDove.
4. Connecting LinkedIn and NeoDove through Pabbly Connect
Now it’s time to establish connections between LinkedIn and NeoDove via Pabbly Connect. Click on the ‘Connect’ button in the LinkedIn trigger window. If you have an existing connection, you can use it; otherwise, create a new one.
Once connected, select your LinkedIn account from the dropdown menu. Next, choose the lead form you want to use. For demonstration, select the ‘Sample Leads In Form’ from your LinkedIn campaign manager. After selecting the form, click on ‘Save and Send Test Request’ to fetch the latest lead data from LinkedIn.
With the lead data fetched, you can now finalize the integration. In the NeoDove action window, click on ‘Connect’ to establish the connection with Pabbly Connect. You will need to input the integration ID from your NeoDove account by navigating to the Integrations section and copying the active integration ID.
Map the fields from the LinkedIn lead response to the corresponding fields in NeoDove, such as phone number, first name, and email address. Once all fields are mapped correctly, click on ‘Save and Send Test Request’ to complete the setup. If successful, a new lead will appear in your NeoDove account, confirming that the integration works seamlessly.
In this tutorial, we explored how to create NeoDove leads from LinkedIn leads using Pabbly Connect. This integration automates the lead management process, ensuring that every new lead captured on LinkedIn is promptly created in NeoDove, enhancing efficiency and productivity.
