Learn how to automate the creation of NeoDove leads from LinkedIn leads using Pabbly Connect. Step-by-step tutorial with detailed instructions. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
Accessing Pabbly Connect for LinkedIn Leads Automation
To create NeoDove leads from LinkedIn leads, access Pabbly Connect by typing ‘Pabbly.com/connect’ in your browser. This platform allows you to automate processes seamlessly between applications.
Once on the homepage, you can either sign in if you are an existing user or click on ‘Sign up for free’ to create an account. After signing in, navigate to the ‘All Applications’ page and click on ‘Pabbly Connect’ to access the dashboard.
After accessing Pabbly Connect, click on the ‘Create Workflow’ button located in the top right corner. In the dialog box, name your workflow, such as ‘Create NeoDove Leads from LinkedIn Leads.’ Organizing your workflow is essential; save it in a designated folder for easy access.
Once the workflow is created, you will see options for setting up a trigger and action. The trigger application will be LinkedIn Leads, while the action application will be NeoDove. This setup will allow your automation to function correctly.
Setting Up the Trigger for LinkedIn Leads in Pabbly Connect
In the trigger section of Pabbly Connect, search for ‘LinkedIn Leads’ and select it as your trigger application. The event should be set to ‘New Lead Gen Form Response.’ This means that every time a new lead is generated, the automation will be triggered.
To establish the connection, click on ‘Connect’. If you have an existing connection, you can use that; otherwise, create a new one. Once connected, choose the appropriate LinkedIn account and select the lead form from the dropdown menu. For this example, you can use the ‘Sample Leads In’ form.
  • Connect to your LinkedIn account.
  • Select the lead form from the dropdown.
  • Click on ‘Save and Send Test Request’ to capture the latest lead.
After clicking ‘Save and Send Test Request,’ you will see the captured lead data, confirming that the trigger is functioning correctly.
Creating a Lead in NeoDove through Pabbly Connect
Next, you will set up the action to create a lead in NeoDove. In the action section of Pabbly Connect, search for ‘NeoDove’ and select it as your action application. Choose the action event ‘Create a Lead’ to proceed.
To connect NeoDove with Pabbly Connect, click on ‘Connect’ and ensure the connection is established. You will need to input the integration ID from your NeoDove account. This ID can be found under the Integrations section in your NeoDove dashboard.
  • Copy the integration ID from NeoDove.
  • Paste it into the Pabbly Connect action settings.
  • Map the necessary fields such as phone number, first name, last name, and email from the LinkedIn lead data.
After mapping the fields, click on ‘Save and Send Test Request’ to finalize the action. You should receive a positive response indicating that the lead has been successfully created in NeoDove.
By following this tutorial, you can easily automate the process of creating NeoDove leads from LinkedIn leads using Pabbly Connect. This integration streamlines your workflow, ensuring that every new lead is captured and processed efficiently.
