Learn how to integrate IndiaMART with NeoDove using Pabbly Connect to automate lead creation seamlessly. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
Accessing Pabbly Connect for IndiaMART and NeoDove Integration
To create a NeoDove lead from IndiaMART, you first need to access Pabbly Connect. This platform allows you to automate workflows seamlessly. Start by visiting the Pabbly Connect website and signing in to your account. If you are a new user, you can sign up for free and receive 100 free tasks every month.
After signing in, navigate to the Pabbly Connect dashboard. Here, you will find various applications. Click on the ‘Access Now’ button under Pabbly Connect. This action will bring you to the main dashboard where you can create workflows to automate your lead generation process.
To set up the integration between IndiaMART and NeoDove, you need to create a workflow in Pabbly Connect. Click on the ‘Create Workflow’ button located in the top right corner of the dashboard. A dialog box will prompt you to enter a name for your workflow. You can name it ‘IndiaMART Automation’ or any name that suits your needs.
Next, select a folder to save your workflow. You can choose from the existing folders or create a new one. Once you have named your workflow and selected the folder, click on the ‘Create’ button. Now, you will see two sections: Trigger and Action. The trigger will be IndiaMART, and the action will be NeoDove.
Setting Up Trigger for IndiaMART in Pabbly Connect
Now, let’s set up the trigger in Pabbly Connect. Click on the arrow in the Trigger section and select ‘IndiaMART’ as your trigger application. Then, choose ‘New Lead’ as the trigger event. Note that IndiaMART operates on a polling basis, meaning it checks for new leads every 24 hours.
To connect IndiaMART with Pabbly Connect, click on the ‘Connect’ button. A new window will appear where you need to add a new connection. Here, you will need the IndiaM CRM API key. To find this, log into your IndiaMART account and go to ‘Settings’ > ‘Account Settings’ > ‘CRM API’. Copy the API key and paste it back into Pabbly Connect. Click ‘Save’ to establish the connection.
Setting Up Action for NeoDove in Pabbly Connect
After setting up the trigger, it’s time to configure the action in Pabbly Connect. Click on the arrow in the Action section and select ‘NeoDove’ as your action application. Choose ‘Create Lead’ as the action event. This means that whenever a new lead is generated in IndiaMART, a corresponding lead will be created in NeoDove automatically.
Next, click on ‘Connect’ to link NeoDove with Pabbly Connect. You will be prompted to enter the Integration ID from your NeoDove account. To find this ID, go to NeoDove, click on ‘Integrations’, and then on ‘View Active Integrations’. Copy the Integration ID and paste it into Pabbly Connect. After this, you will map the data fields from the previous step to ensure the correct information is sent to NeoDove.
- Map the mobile number from the previous step.
- Map the name and email address fields accordingly.
- Ensure all fields are filled to create a complete lead.
Once you have mapped all the necessary data, click on ‘Save and Send Test Request’ to check if the integration works correctly. If successful, you should see a confirmation response.
Verifying Lead Creation in NeoDove
To confirm that the integration between IndiaMART and NeoDove was successful, you need to check your NeoDove account. Refresh the page to see if a new lead has been created based on the data received from IndiaMART. If everything is set up correctly, you will find a new lead with the details you mapped earlier.
This process demonstrates how Pabbly Connect facilitates the automation of lead generation between IndiaMART and NeoDove. You can now easily manage your leads without manual data entry, ensuring efficiency and accuracy in your sales process.
In this tutorial, we learned how to create a NeoDove lead from IndiaMART using Pabbly Connect. By following the steps outlined, you can automate your lead generation process effectively. This integration enhances your workflow and saves valuable time.
