Learn how to automate the creation of Mautic contacts for every ThriveCart purchase using Pabbly Connect. Follow our step-by-step guide to streamline your workflow. Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
1. Introduction to Pabbly Connect for ThriveCart and Mautic Integration
Pabbly Connect is a powerful automation tool that allows users to integrate various applications seamlessly. In this tutorial, we will show you how to use Pabbly Connect to create a contact in Mautic for every purchase made through ThriveCart. This integration saves time and eliminates manual data entry.
To get started, you need to sign up for Pabbly Connect and log into your account. Once logged in, you can access the dashboard to create your workflow. This process involves setting up triggers and actions to automate your workflow effectively.
2. Setting Up the Trigger for ThriveCart Purchases
The first step in using Pabbly Connect is to set up a trigger that will initiate the workflow whenever a purchase is made in ThriveCart. Click on the ‘Create Workflow’ button in Pabbly Connect and name your workflow appropriately.
Next, select ThriveCart as the trigger application. Then, choose the trigger event as ‘Product Purchase’. After this, connect your ThriveCart account by adding a new connection and entering the API key from your ThriveCart account settings. Follow these steps to obtain your API key:
  • Go to your ThriveCart account settings.
  • Click on ‘API and Webhooks’.
  • Generate a new API key and copy it.
After saving the connection, you can select the product for which you want to set up the automation.
3. Creating a Contact in Mautic Using Pabbly Connect
Once the trigger is set up in Pabbly Connect, the next step is to create a contact in Mautic whenever a purchase occurs. Select Mautic as the action application and choose the action event as ‘Create or Update Contact’. Connect to your Mautic account by providing your username and password.
To find the base URL for your Mautic account, go to the settings section and copy the site URL. Enter this URL in Pabbly Connect when prompted. After establishing the connection, you’ll see various fields where you can map the customer details from ThriveCart to Mautic. Make sure to map important fields like first name, last name, and email address.
To map these fields, click on each input field and select the corresponding data from the ThriveCart trigger. This ensures that each new purchase automatically creates a contact with the correct information in Mautic.
4. Testing the Integration Between ThriveCart and Mautic
After setting up the connection and mapping the necessary fields, it’s time to test the integration. Click on the ‘Save and Send Test Request’ button in Pabbly Connect. This will attempt to create a new contact in Mautic based on the test data from the ThriveCart purchase.
To perform the test, make a test purchase through your ThriveCart checkout page. Fill in the required details and use the test card information provided by ThriveCart. Once the purchase is complete, you should see a response in Pabbly Connect confirming that the contact has been successfully created in Mautic.
After testing, navigate to your Mautic account to confirm that the new contact appears in the contact section. This verifies that the integration is working as intended and that every purchase will automatically create a contact in Mautic moving forward.
5. Conclusion: Automating Your Workflow with Pabbly Connect
In this tutorial, we demonstrated how to use Pabbly Connect to automate the creation of Mautic contacts for every ThriveCart purchase. This integration significantly streamlines your workflow, saving you time and effort.
By setting up this automation, you ensure that all customer data is accurately transferred to Mautic without any manual input. This not only enhances productivity but also improves your marketing efforts by keeping your contact list updated automatically. Start using Pabbly Connect today to integrate your applications seamlessly!
