Learn how to create Mailmodo contacts for Instagram Lead Ads leads using Pabbly Connect. Follow this step-by-step tutorial for seamless integration. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
To create Mailmodo contacts for Instagram Lead Ads leads, the first step is to access Pabbly Connect. This platform allows you to automate the process of adding new leads to your Mailmodo account.
Navigate to the Pabbly Connect homepage by entering the URL in your browser. You will see options for signing in or signing up. New users should click on ‘Sign Up Free’ to explore the platform, while existing users can simply sign in.
Once signed into Pabbly Connect, you will be directed to the dashboard. Here, you can create a new workflow by clicking on the ‘Create Workflow’ button located at the top right corner.
- Name your workflow as ‘Create Mailmodo Contacts for Instagram Lead Ads Leads’.
- Select a folder for your workflow, such as ‘Automations’.
- Click on the ‘Create’ button to finalize the workflow setup.
Now, your new workflow is ready, and you can proceed to set up the trigger and action steps required for the integration.
3. Setting Up Trigger in Pabbly Connect
In this step, you will configure the trigger application in Pabbly Connect. Select ‘Instagram Lead Ads’ as the trigger application and set the trigger event to ‘New Lead’.
To connect your Instagram Lead Ads with Pabbly Connect, click on ‘Connect’ and then select ‘Add New Connection’. Provide a name for your connection, such as ‘Mailmodo Contact’. This allows Pabbly Connect to capture new leads instantly.
- Ensure you are logged into your Facebook account for seamless connection.
- Select your Facebook page linked to Instagram.
- Choose the lead form from your campaign.
After configuring these settings, click on ‘Save and Send Test Request’ to ensure everything is set up correctly.
4. Adding Contacts to Mailmodo
Now that the trigger is set, it’s time to configure the action application in Pabbly Connect. Select ‘Mailmodo’ as the action application and choose the event ‘Add a Contact to List’.
To connect Mailmodo with Pabbly Connect, click on ‘Connect’ and then select ‘Add New Connection’. Provide a name for your connection and enter the API key from your Mailmodo account.
Log into your Mailmodo account and navigate to settings to generate an API key. Copy the API key and paste it into Pabbly Connect. Map the lead details such as email, full name, and phone number from the previous step.
Once you have mapped all the necessary fields, click on ‘Save and Send Test Request’ to finalize the setup. You should receive a confirmation that the contact was successfully added to your Mailmodo account.
5. Testing the Integration
To ensure that the integration works seamlessly, you need to test it by generating a new lead in your Instagram Lead Ads. Use the Meta Lead Testing Tool to create a test lead.
After generating a new lead, return to Pabbly Connect and check if the contact appears in your Mailmodo account. This confirms that the workflow is functioning properly.
Delete any previous test leads to avoid conflicts. Refresh your Mailmodo account after submitting a new lead. Verify that the new contact details match the submitted information.
By following these steps, you have successfully set up and tested the integration between Instagram Lead Ads and Mailmodo using Pabbly Connect.
In this tutorial, we explored how to create Mailmodo contacts for Instagram Lead Ads leads using Pabbly Connect. This integration automates the process, ensuring that new leads are added to your Mailmodo account seamlessly. By following these steps, you can enhance your marketing efforts and manage your leads more efficiently.
