Learn to automate Mailgun member creation on FlexiFunnels purchases using Pabbly Connect. Follow this step-by-step tutorial for seamless integration. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
To start the integration between FlexiFunnels and Mailgun, you first need to access Pabbly Connect. Open your web browser and navigate to the Pabbly Connect landing page. Here, you can either sign in if you are an existing user or sign up for free if you are new.
After signing in, you will see all the Pabbly applications. Click on Pabbly Connect to access the dashboard. From there, you can create a new workflow to automate the process of adding a Mailgun member whenever a purchase is made on FlexiFunnels.
Once you are in Pabbly Connect, click on the button that says ‘Create Workflow’. You will be prompted to name your workflow. For this integration, name it ‘How to Create a New Mailgun Member on FlexiFunnels Purchase’ and select a folder to save it in.
- This opens the workflow window where you will set up triggers and actions.
In this window, you need to set up a trigger application. Select FlexiFunnels as your trigger application and choose the trigger event as ‘New Purchase’. This event will initiate the workflow whenever a new purchase is made through FlexiFunnels.
3. Setting Up Webhook URL in FlexiFunnels
After selecting the trigger event, Pabbly Connect will generate a webhook URL. Copy this URL as you will need it to connect FlexiFunnels with your Pabbly Connect workflow. Next, log into your FlexiFunnels account.
In your FlexiFunnels dashboard, navigate to the product you want to integrate, click on ‘Edit’, and go to the ‘Set Rules’ section. Here, you will add a product rule to trigger the webhook:
- Select ‘Product is Purchased’ as the event.
- Choose ‘Webhook’ as the action and paste the copied webhook URL.
After saving these settings, your FlexiFunnels account is now connected to Pabbly Connect. This setup enables the workflow to trigger when a purchase is made.
4. Testing the Integration with a Purchase
To ensure that the integration works correctly, you must perform a test purchase through FlexiFunnels. Enter the necessary details and complete the order. After the purchase, return to your Pabbly Connect dashboard to check if the webhook response was received.
Once the purchase is completed, you should see the data captured in Pabbly Connect. This data includes customer details such as name, email, and phone number. Confirm that all details are correct, as this information will be used to create a new Mailgun member.
5. Adding a Mailgun Member Through Pabbly Connect
After confirming that the webhook response is received, you can proceed to add a Mailgun member. In your Pabbly Connect workflow, select Mailgun as the action application. Choose the action event as ‘New Mailing List Member’.
To connect your Mailgun account, you will need to enter the API key, private API key, and domain name. Follow these steps:
Enter the Mailgun host based on your region (US or EU). Copy your domain name from Mailgun and paste it into the workflow. Generate a new API key in your Mailgun account and paste it into the corresponding field.
After entering all required details, map the email address and name fields using data from the previous trigger step. Click ‘Save and Send Test Request’ to finalize the process. Once successful, you will see the new member added to your Mailgun account.
In this tutorial, you learned how to automate the creation of Mailgun members using Pabbly Connect whenever a purchase is made on FlexiFunnels. This integration streamlines your email marketing efforts and eliminates manual entry, allowing for a more efficient workflow.
