Learn how to automatically create MailerLite subscribers from Webflow form submissions using Pabbly Connect. Follow our step-by-step tutorial. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
To create a MailerLite subscriber from Webflow form submissions, you need to access Pabbly Connect. Start by navigating to the Pabbly Connect website in your browser.
Once there, you can either sign in if you already have an account or click on ‘Sign Up for Free’ to create a new account. This process is quick, and new users receive 100 free tasks to explore the platform.
After signing in to Pabbly Connect, you will be directed to the dashboard. Here, click on the blue ‘Create Workflow’ button located at the top right corner.
- Name your workflow as ‘Create MailerLite Subscribers from Webflow Form Submission’.
After creating the workflow, you will see two sections: Trigger and Action. For this integration, Webflow will be your trigger application, and MailerLite will be your action application.
3. Setting Up Webflow as the Trigger
In the trigger section, select Webflow as your trigger application and choose the ‘New Form Submission’ event. Pabbly Connect will provide you with a webhook URL.
Next, go to your Webflow account and locate the form you want to connect. Click on the settings icon (three dots) next to the form, select ‘Settings’, then go to ‘Integrations’.
- Click on ‘Add New Webhook’.
- Paste the webhook URL from Pabbly Connect.
- Set the trigger type to ‘Form Submission’ and click ‘Add Webhook’.
Once this is set, return to Pabbly Connect and test the connection by submitting a form in Webflow.
4. Setting Up MailerLite as the Action
Now that your trigger is set, move to the action section and select MailerLite as your action application. Choose the ‘Add or Update Subscriber’ event. using Pabbly Connect
Connect your MailerLite account by clicking on ‘Connect’, then ‘Add New Connection’. You will need your MailerLite API key, which can be found in your MailerLite account under ‘Integrations’ in your profile settings.
Copy the API key from MailerLite. Paste it into Pabbly Connect and click ‘Save’.
Next, select the group where you want to add the new subscriber and map the fields such as email and name from the previous Webflow submission step.
5. Testing the Integration and Finalizing
After mapping the fields, it’s time to test the integration. Click on ‘Save and Send Test Request’ in Pabbly Connect to see if the subscriber is added to MailerLite.
Once confirmed, you will receive a confirmation email at the email address provided in the form submission. You must confirm this email to finalize the subscription.
Check your MailerLite subscribers list to verify the new subscriber has been added. Ensure the subscriber is in the correct group as specified.
This successful integration allows you to automate the process of adding subscribers from Webflow to MailerLite using Pabbly Connect.
In this tutorial, we demonstrated how to create MailerLite subscribers from Webflow form submissions using Pabbly Connect. This integration streamlines your process, allowing for automatic subscriber management and enhanced workflow efficiency.
