Learn how to create MailerLite subscribers from IndiaMART leads using Pabbly Connect. This detailed tutorial covers all steps for seamless integration. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
To create a MailerLite subscriber from IndiaMART leads, you first need to access Pabbly Connect. Start by visiting the Pabbly website and signing in or signing up for a free account.
Upon logging in, you will see various Pabbly applications. Click on Pabbly Connect to begin creating your integration. This platform will enable you to connect IndiaMART and MailerLite seamlessly.
After accessing Pabbly Connect, you need to create a new workflow. Click on the button labeled ‘Create Workflow’. This action will prompt you to name your workflow and select a folder for organization.
  • Name your workflow as ‘IndiaMART Automation’
  • Choose a folder, such as ‘Automations’
Once you have named your workflow, click on ‘Create’. You will be directed to the workflow window where you can set up triggers and actions for your automation process.
In the workflow window of Pabbly Connect, select IndiaMART as your trigger application. Choose the trigger event as ‘New Leads’. This setup allows the workflow to activate whenever a new lead is generated in your IndiaMART account.
Next, click on ‘Connect’ to link your IndiaMART account to Pabbly Connect. You will need to provide your CRM API key from your IndiaMART account. To find this key, navigate to Settings, then Account Settings, and finally, CRM API.
  • Copy your CRM API key from the IndiaMART settings
  • Paste the key into the Pabbly Connect workflow
After pasting the key, click ‘Save’. This action will connect your IndiaMART account to Pabbly Connect, enabling the capture of new leads.
Once the trigger is set up, it’s time to configure the action. For the action application, select MailerLite and choose the event ‘Create or Update Subscriber’. This action ensures that whenever a new lead is captured, a corresponding subscriber is created in MailerLite.
Click ‘Connect’ to link your MailerLite account. You will need to provide your MailerLite API token, which can be found in the Integrations section of your MailerLite account. Generate a new token if you haven’t already.
Navigate to Integrations in MailerLite Generate a new API token
Copy the token and paste it into the action setup in Pabbly Connect. After saving this connection, you can now map the subscriber details from the lead captured.
5. Mapping Data and Testing the Workflow
In this step, you will map the data from the IndiaMART lead to the MailerLite subscriber fields. Ensure that you switch on the mapping option and select the relevant fields such as email, name, city, and state from the lead data captured in the trigger.
Once you have mapped all necessary fields, click on ‘Save and Send Test Request’. This action will send the data to MailerLite and create the subscriber. If successful, you will see a confirmation message indicating that a new subscriber has been created.
Map the email from the lead to the subscriber email field Ensure all required fields are filled correctly
After completing these steps, you can verify the new subscriber by checking your MailerLite subscriber list. This confirms that your workflow using Pabbly Connect is functioning correctly.
Using Pabbly Connect, you can efficiently create MailerLite subscribers from IndiaMART leads. This integration automates the process, ensuring that new leads are automatically added to your mailing list, enhancing your marketing efforts.
