Learn how to seamlessly integrate Circle with MailerLite using Pabbly Connect to automate subscriber creation for new Circle members. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
To create a MailerLite subscriber for Circle members, you first need to access Pabbly Connect. Start by visiting the Pabbly Connect homepage. If you are a new user, click on the ‘Sign Up for Free’ button to create your account. This process takes only a few minutes and provides you with 100 free tasks to explore the platform.
After signing in, navigate to the dashboard where you can manage your workflows. Click on the ‘Create Workflow’ button located in the upper right corner. You will then need to name your workflow; for this tutorial, you can name it ‘Create MailerLite Subscribers for Circle Members’. Click on ‘Create’ to proceed.
2. Setting Up the Trigger with Circle
In this step, you will set up the trigger application, which will be Circle. Select Circle as your trigger application within Pabbly Connect. Next, choose the trigger event as ‘New Member’. This event will capture details whenever a new member is added to your Circle community.
- Select Circle as the trigger application.
- Choose ‘New Member’ as the trigger event.
- Click on ‘Connect’ to establish a connection.
To connect Circle with Pabbly Connect, you will need to enter your API token and host details. The host is derived from your Circle URL, and the API token can be generated from the settings section of your Circle account. After entering these details, click ‘Save and Send Test Request’ to ensure the connection is successful.
3. Testing Member Creation in Circle
Before proceeding to the action step, you need to create a test member in Circle to capture their details. Go to the members section and click on ‘Invite’. Fill in the name and email of the new member, and then click ‘Invite’. Once the member accepts the invitation, they will be added to your Circle community.
After the member has accepted the invitation, return to Pabbly Connect. Click on ‘Save and Send Test Request’ to capture the details of the newly created member, including their name and email. This data will be used in the next step to create a subscriber in MailerLite.
4. Integrating MailerLite as Action Step
Now that you have captured the member’s details, it’s time to set up MailerLite as the action application in Pabbly Connect. Select MailerLite as the action application and choose the action event as ‘Create or Update Subscriber’. Click on ‘Connect’ to establish a connection with MailerLite.
- Select MailerLite as the action application.
- Choose ‘Create or Update Subscriber’ as the action event.
- Enter your MailerLite API key to connect.
After connecting, you need to fill in the details for the new subscriber. Map the fields from the Circle response to the corresponding fields in MailerLite, such as email, first name, and last name. Finally, click ‘Save and Send Test Request’ to create the subscriber in MailerLite.
5. Confirming Subscriber Creation in MailerLite
After sending the test request, check your MailerLite account to confirm that the new subscriber has been created successfully. The subscriber’s status will initially be unconfirmed as MailerLite sends a confirmation email. Make sure to check the email for the confirmation link.
Once the new subscriber confirms their email, they will be added to the specified group in MailerLite. You can verify this by refreshing the subscriber list in MailerLite and checking the group where the subscriber was added. This process demonstrates how Pabbly Connect efficiently automates the integration between Circle and MailerLite.
In this tutorial, we explored how to use Pabbly Connect to create a MailerLite subscriber for new Circle members. By following the steps outlined, you can automate subscriber management effectively. This integration streamlines your workflow and enhances community engagement.
