Learn how to integrate Mailercloud with Studiocart using Pabbly Connect. This step-by-step tutorial guides you through creating contacts automatically for every new order. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
To create a Mailercloud contact for every new Studiocart order, the first step is to set up Pabbly Connect. This powerful integration platform allows you to automate tasks without any coding. Start by signing up on the Pabbly Connect website and logging into your dashboard.
Once you are in the dashboard, click on the ‘Create Workflow’ button. Here, you can name your workflow. For instance, you might name it ‘Mailercloud Contact Creation’. After naming it, click the ‘Create’ button to proceed to the workflow page where you can set up triggers and actions.
2. Triggering New Orders from Studiocart
In this step, you will configure the trigger event in Pabbly Connect. The trigger event will be a new order placed on your Studiocart. Click on the trigger application and search for ‘Studiocart’. Select the trigger event as ‘New Order’. It’s important to choose the correct event type based on your store’s configuration.
- Select ‘New Order’ as the trigger event.
- Click on the connect button and choose ‘Add New Connection’.
- Enter your WordPress site URL without an ending slash.
After entering the URL, you will need to provide the API key from your Studiocart settings. This key is essential for authenticating the connection between Pabbly Connect and your Studiocart account. Once everything is entered, click on ‘Save’ to establish the connection.
3. Mapping Product Details for Automation
Next, you will need to map the product details that will trigger the workflow in Pabbly Connect. After saving the connection, the platform will prompt you to enter the product ID. You can find this ID by editing the product in your Studiocart plugin and copying the ID from the URL.
Make sure to paste the product ID in the designated field in Pabbly Connect. After entering the product ID, click on ‘Save and Send Test Request’. This action will allow the platform to listen for any new orders placed.
4. Creating Mailercloud Contact from Orders
After setting up the trigger, you will now create a Mailercloud contact using the data received from the Studiocart order. In the action step, search for ‘Mailercloud’ and select the action event as ‘Add Contact to List’. Click on the connect button and choose ‘Add New Connection’ to input your Mailercloud API key.
- Access your Mailercloud account and generate a new API key.
- Paste the API key into Pabbly Connect.
- Select the list where you want to add the contact.
Once connected, map the customer details from the Studiocart order to the Mailercloud fields. Ensure that you map the email, first name, last name, and phone number. After mapping the fields, click on ‘Save and Send Test Request’ to verify that the integration works as expected.
The final step is to test the integration to ensure that everything is functioning correctly. Place a test order on your Studiocart store. After completing the order, return to Pabbly Connect and check if the data from the test order has been captured in the workflow.
If the test order details appear correctly, you will see a new contact added to your Mailercloud list. This means that the integration between Studiocart and Mailercloud via Pabbly Connect is successful. You can now automate the process of adding new contacts for every order placed in your store.
In conclusion, integrating Mailercloud with Studiocart using Pabbly Connect streamlines your email marketing efforts. By automating contact creation for every new order, you enhance communication with your customers effectively.
