Learn how to create a Mailchimp subscriber from Typeform submissions using Pabbly Connect. Follow our step-by-step tutorial for seamless integration. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
To create a Mailchimp subscriber from Typeform submissions, you first need to access Pabbly Connect. This platform enables seamless integrations between various applications.
Visit the Pabbly Connect homepage by entering the URL Pabbly.com/connect. Here, you will find options to either sign in or sign up for free. New users can click on ‘Sign up free’ to get 300 tasks every month, while existing users can simply sign in.
Once you are signed in, you will see the ‘All Pabbly Apps’ window. Click on the ‘Create Workflow’ button located at the top right corner to start setting up your integration. using Pabbly Connect
- Name your workflow as ‘Create Mailchimp Subscriber from Typeform Submission’.
- Select a folder to save your workflow, such as ‘Automations’.
- Click on the ‘Create’ button to finalize the setup.
After creating the workflow, you will see the two main components: Trigger and Action. The Trigger application will be Typeform, and the Action application will be Mailchimp.
3. Setting Up the Trigger with Typeform
Now, let’s set up the trigger. In Pabbly Connect, select Typeform as your trigger application and choose ‘New Entry’ as the trigger event. This setup ensures that every new submission in Typeform will initiate the workflow.
To connect Typeform with Pabbly Connect, click on ‘Connect’ and select ‘Add New Connection’. You will need to authorize Pabbly Connect by clicking on the ‘Accept’ button to allow access to your Typeform account.
Next, select the specific form you created in Typeform, such as the ‘Registration Form’. After selecting the form, click on ‘Save and Send Test Request’ to receive a response, which will confirm that the connection is successful.
4. Configuring the Action Step with Mailchimp
After successfully setting up the trigger, the next step is to configure the action. Select Mailchimp as your action application and choose ‘Add New Member with Custom Fields’ as the action event.
- Click on ‘Connect’ to build a new connection with Mailchimp.
- Enter the API Key and Data Center from your Mailchimp account.
- Select your audience list in Mailchimp.
To retrieve your API Key, log in to your Mailchimp account, navigate to your profile, click on ‘Extras’, and then select ‘API Keys’. Generate a new API key, copy it, and paste it back into Pabbly Connect. Enter the Data Center, which can be found in the Mailchimp URL.
5. Testing the Integration
With both the trigger and action steps configured, it’s time to test the integration. Go back to Typeform and submit a test entry using dummy data. This submission will trigger the workflow in Pabbly Connect.
After submitting the test data, return to Pabbly Connect and check the response. You should see the details of the submission, confirming that the trigger worked correctly. Now, check your Mailchimp account to verify that the new subscriber has been added successfully.
Repeat the test submission process with different dummy data to ensure that the automation works consistently. This setup allows you to create new Mailchimp subscribers automatically from Typeform submissions.
In this tutorial, we demonstrated how to create a Mailchimp subscriber from Typeform submissions using Pabbly Connect. This integration automates the process, ensuring new subscribers are added seamlessly to your Mailchimp account. With Pabbly Connect, you can streamline your workflows and enhance your productivity.
