Learn how to automate LinkedIn posts using Google Gemini and Pabbly Connect with this detailed step-by-step tutorial. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
1. Setting Up Pabbly Connect for LinkedIn Posts
To create LinkedIn posts using Google Gemini, the first step is to set up Pabbly Connect. This platform facilitates the integration between Google Sheets and LinkedIn, streamlining the posting process. Start by accessing the Pabbly Connect website and signing up or logging into your account.
Once logged in, navigate to the dashboard and click on the ‘Create Workflow’ button. You will be prompted to name your workflow, for example, ‘Create LinkedIn Posts using Google Gemini’. Select an appropriate folder to save your workflow and click ‘Create’. This setup is essential for automating your LinkedIn posting process.
2. Connecting Google Sheets with Pabbly Connect
The next step involves connecting Google Sheets to Pabbly Connect to track new post details. In your workflow, you will set Google Sheets as your trigger application. Click on the trigger application box and select Google Sheets, then choose the trigger event as ‘New or Updated Spreadsheet Row’.
After copying the webhook URL, go to your Google Sheets document. Under the Extensions menu, find and install the Pabbly Connect Webhooks add-on if you haven’t done so. Once installed, refresh your Google Sheet and go to the initial setup of the add-on to connect your sheet with Pabbly Connect.
3. Generating Post Content with Google Gemini
After setting up the trigger, the next step is to generate the post content using Google Gemini through Pabbly Connect. In your workflow, add an action step and select Google Generative AI as the application. Choose ‘Generate Content’ as the action event.
To connect Google Gemini with Pabbly Connect, you will need to provide an API key. Log in to your Google Gemini account, navigate to Google AI Studio, and generate a new API key. Once you have the API key, paste it into Pabbly Connect to establish the connection.
  • Select Google Generative AI as the action application.
  • Set the action event to ‘Generate Content’.
  • Map the post title from Google Sheets to your content prompt.
By using the mapped title in your prompt, Google Gemini will generate a professional and engaging description for your LinkedIn post. Ensure that you select the appropriate model for content generation before saving your settings.
4. Posting to LinkedIn Using Pabbly Connect
With the content generated, the final step is to post it to LinkedIn through Pabbly Connect. Add another action step in your workflow and select LinkedIn as the application. Choose ‘Share Text with Image’ as the action event.
Connect your LinkedIn account to Pabbly Connect, ensuring you select the correct author for the post. Map the generated content and image URL from your previous steps to the LinkedIn post fields. This mapping ensures that the correct title, description, and image are used in your LinkedIn post.
Select LinkedIn as the action application. Choose ‘Share Text with Image’ as the action event. Map the title, description, and image URL to the LinkedIn post fields.
After mapping all necessary fields, save your settings and test the connection. If successful, you will see your new post appear on your LinkedIn account, demonstrating the effectiveness of this integration.
5. Conclusion: Automating LinkedIn Posts with Pabbly Connect
In this tutorial, we explored how to use Pabbly Connect to automate the creation of LinkedIn posts using Google Gemini. By integrating Google Sheets, Google Gemini, and LinkedIn, we streamlined the process of generating and posting content. This automation not only saves time but also ensures consistent and engaging posts.
By following the steps outlined, you can easily set up your own automated workflow for LinkedIn posts. Pabbly Connect simplifies the integration process, allowing you to focus on creating quality content for your audience.
