Learn to automate LinkedIn posts from Facebook Page posts using Pabbly Connect. Step-by-step guide for seamless integration without coding. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
To create a LinkedIn post from a Facebook Page post, you first need to access Pabbly Connect. This platform allows you to automate tasks without coding. Simply visit the Pabbly Connect website and sign in or sign up for a free account.
After signing in, you will be greeted by the dashboard where you can manage your workflows. If you are a new user, you will receive 100 free tasks monthly to explore automation features. Once logged in, navigate to the ‘Create Workflow’ option to begin setting up your integration.
In this step, you will create a workflow to link Facebook Page posts to LinkedIn. Start by selecting ‘Create Workflow’ and name it appropriately, such as ‘Create LinkedIn Post from Facebook Page Post’. Choose a folder for organization, such as ‘Social Media Automations’.
  • Click on ‘Create’ to initiate the workflow.
  • Select Facebook Pages as your trigger application.
  • Choose ‘New Post’ as the trigger event.
This setup establishes that whenever a new post is created on your Facebook Page, it will trigger an action to post on LinkedIn through Pabbly Connect.
3. Connecting Facebook Pages to Pabbly Connect
Next, you need to connect your Facebook account to Pabbly Connect. Click on ‘Connect’ after selecting the trigger event. You will be prompted to add a new connection or select an existing one. Choose to add a new connection to link your Facebook account.
Once connected, select the specific Facebook Page you want to use for posting. For this example, select ‘Sparkle Evenings’. After making your selection, click on ‘Save and Send Test Request’ to capture the response from Facebook. This step is crucial as it confirms that the connection is successful.
4. Setting Up LinkedIn Action in Pabbly Connect
Now that Facebook is connected, it’s time to set up the action for LinkedIn. Choose LinkedIn as your action application in Pabbly Connect. Select the action event as ‘Share Text with Image’. This will allow you to post the same content on LinkedIn.
Connect your LinkedIn account similarly by either selecting an existing connection or adding a new one. Once connected, you will need to fill out the required fields, such as the author and image file URL. Use the mapped data from the Facebook post to ensure that the correct content is shared.
  • Map the image URL and caption from the Facebook post.
  • Select visibility settings for your LinkedIn post.
  • Click ‘Save and Send Test Request’ to finalize the setup.
This configuration ensures that every new Facebook post is automatically shared on LinkedIn with the same caption and image.
5. Testing the Integration Between Facebook and LinkedIn
Finally, it’s time to test the integration. Create a new post on your Facebook Page, such as ‘Transforming events into unforgettable experiences’ along with an image. After posting, return to Pabbly Connect to check if the response is captured successfully.
Once the response is confirmed, check your LinkedIn account. You should see the same post appear automatically. This validation confirms that your workflow is functioning correctly and that Pabbly Connect is effectively linking your Facebook and LinkedIn accounts.
Using Pabbly Connect, you can effortlessly automate the sharing of Facebook Page posts to LinkedIn. This integration allows for streamlined social media management without any coding required. Start automating your social media tasks today with Pabbly Connect!
