Learn how to automate posting on LinkedIn from Facebook Page posts using Pabbly Connect. Step-by-step tutorial for seamless integration. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
To create a LinkedIn post from a Facebook Page post, you first need to access Pabbly Connect. This powerful automation tool allows you to connect various applications without any coding skills. Start by visiting the Pabbly Connect website and either sign in or sign up for a free account.
Once you are logged in, you will have access to a dashboard that displays all your workflows. If you are a new user, you will receive 100 free tasks every month to explore the automation capabilities of Pabbly Connect.
Next, you need to create a new workflow in Pabbly Connect. Click on the ‘Create Workflow’ button and name your workflow ‘Create LinkedIn Post from Facebook Page Post.’ Select the appropriate folder to save your workflow.
  • Click on ‘Create’ to initiate the workflow.
  • Understand that the workflow consists of a trigger and an action.
  • Set Facebook Pages as the trigger and LinkedIn as the action.
After setting this up, you will see two windows: one for the trigger and one for the action. This setup is essential for automating the process of sharing Facebook posts on LinkedIn through Pabbly Connect.
3. Set Facebook Pages as Trigger Application
In this step, select Facebook Pages as your trigger application in Pabbly Connect. Choose the trigger event as ‘New Post’ to ensure that the workflow activates every time a new post is published on your Facebook page.
Click on ‘Connect’ and select ‘Add New Connection’ to link your Facebook account. After logging in, authorize the connection. Once connected, select the specific Facebook page from which you want to pull posts, such as ‘Sparkle Evenings.’ Click on ‘Save and Send Test Request’ to capture the response from your Facebook page.
4. Set LinkedIn as Action Application
Now that you have set up Facebook as the trigger, it’s time to configure LinkedIn as the action application in Pabbly Connect. Select LinkedIn and choose the action event ‘Share Text with Image’ to post the content from your Facebook page.
Click on ‘Connect’ and either select an existing connection or create a new one. After successfully connecting LinkedIn, you will need to map the details from your Facebook post to LinkedIn. This includes selecting the author and the image file URL from the previous step’s response.
  • Map the image URL to ensure the correct image is shared.
  • Map the text content to include the caption from the Facebook post.
  • Choose the visibility settings for your LinkedIn post.
Once everything is mapped correctly, click on ‘Save and Send Test Request’ to verify that the post is shared on LinkedIn successfully. This completes the integration process using Pabbly Connect.
5. Test the Automation Process
To ensure your setup works, create a new post on your Facebook page. For example, you might write, ‘Transforming events into Unforgettable experiences’ and include an image. After posting, return to Pabbly Connect and check if the response was captured successfully.
Then, head to LinkedIn to verify that the post was shared automatically with the same caption and image. If everything is set up correctly, you should see the post appear on your LinkedIn profile. This confirms that the automation is functioning as intended.
Now, every time you make a new post on your Facebook page, it will automatically share on LinkedIn without any manual effort. This is the power of automation through Pabbly Connect.
In conclusion, using Pabbly Connect allows you to seamlessly automate the process of creating LinkedIn posts from Facebook Page posts. This integration saves time and ensures consistent sharing across platforms, enhancing your social media presence effortlessly.
