Learn how to automate the creation of Kit subscribers from Typeform submissions using Pabbly Connect in this detailed step-by-step tutorial. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
1. Accessing Pabbly Connect for Typeform Integration
To create a Kit subscriber on Typeform submission, we will use Pabbly Connect. First, navigate to the Pabbly Connect website and sign in to your account. If you are a new user, you can sign up for free and get access to 100 free tasks each month.
Once logged in, you will see the Pabbly Apps window. Click on the ‘Access Now’ button for Pabbly Connect. This will take you to the Pabbly Connect dashboard where you can begin creating your automation workflow.
In the Pabbly Connect dashboard, to start the automation process, click on the ‘Create Workflow’ button located at the top right corner. A dialog box will appear asking for the workflow name and folder selection. using Pabbly Connect
  • Name your workflow: ‘Create Kit Subscriber on Typeform Submission’.
  • Select a folder to save your workflow. Choose the ‘Typeform Automations’ folder.
After naming your workflow and selecting the folder, click the ‘Create’ button. You will now see two sections labeled ‘Trigger’ and ‘Action’ on your screen, which are essential for setting up your automation.
3. Setting Up Trigger in Pabbly Connect
For the trigger application, select ‘Typeform’. This is where we will capture new form submissions. Choose the trigger event as ‘New Entry’. This means that every time a new submission is made, it will trigger the workflow. using Pabbly Connect
  • Click on the ‘Connect’ button.
  • Select ‘Add New Connection’ or choose an existing one.
  • Authorize Pabbly Connect to access your Typeform account by clicking ‘Accept’.
After authorizing, you will need to select the form you created in Typeform. Choose the form named ‘Contact Us Form’. Click on ‘Save and Send Test Request’ to ensure that Pabbly Connect captures the response correctly.
4. Testing Trigger Connection in Pabbly Connect
To test the connection, perform a test submission on your Typeform. Copy the form link from the ‘Share’ button and paste it into a new tab. Fill in the required fields such as first name, last name, phone number, and email, then click the ‘Submit’ button.
After submitting the form, return to Pabbly Connect and check if the response has been captured. You should see the first name, last name, phone number, and email displayed in the trigger section. This confirms that Typeform is successfully connected to Pabbly Connect.
5. Setting Up Action in Pabbly Connect
Now that the trigger is set up, it’s time to create the subscriber in your Kit account. For the action application, select ‘Kit’ and the action event as ‘Add Subscriber to a Form’. Click on the ‘Connect’ button and choose to add a new connection. using Pabbly Connect
Enter your API Key and API Secret from your Kit account settings. Select the form where you want to add the subscriber, typically named ‘Leads Form’. Map the data fields for first name, email, and tags as necessary.
After mapping the data, click on ‘Save and Send Test Request’. If successful, you will receive a subscription ID confirming that the subscriber has been created in your Kit account. Check your Kit subscribers page to verify the new subscriber has been added.
This tutorial demonstrated how to create a Kit subscriber on Typeform submission using Pabbly Connect. By following these steps, you can automate the process of adding subscribers seamlessly, ensuring efficient lead management and engagement.
