Learn how to automate subscriber creation in Kit with Jotform submissions using Pabbly Connect. Step-by-step guide for seamless integration. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
To create a Kit subscriber on Jotform submission, we will use Pabbly Connect. First, navigate to the Pabbly Connect website by typing ‘Pabbly.com/connect’ in your browser. After reaching the landing page, you will need to sign in to your account. If you are a new user, click on ‘Sign up for free’ to get started.
Once you log in, you will be directed to the Pabbly Connect dashboard. Here, you can manage your workflows and integrations. To begin, click on the ‘Create Workflow’ button. Name your workflow as ‘Create Kit Subscriber on Jotform Submission’ and select a folder for organization. This sets the stage for integrating Jotform with Kit through Pabbly Connect.
2. Setting Up Jotform as the Trigger Application
In this step, we will configure Jotform as the trigger application in Pabbly Connect. After naming your workflow, you will see two boxes for setting up the trigger and action. Select Jotform as the trigger application and choose ‘New Response’ as the trigger event. This means that whenever a new form is submitted in Jotform, it will trigger the workflow.
- Select Jotform as the trigger application.
- Choose ‘New Response’ as the trigger event.
- Copy the provided webhook URL for integration.
Next, you will need to integrate this webhook URL into Jotform. Go to your Jotform account, select the form you want to use, and click on ‘Settings’. Then navigate to ‘Integrations’ and select ‘Webhook’. Paste the copied URL into the field and complete the integration. This step ensures that every new submission in Jotform is sent to Pabbly Connect.
3. Testing the Webhook Connection
After setting up the webhook, it is essential to test the connection to ensure everything is working correctly. In Pabbly Connect, you will see a message indicating it is waiting for a response from the webhook. To test this, go back to Jotform and submit a test form with dummy data.
Once you submit the form, return to Pabbly Connect. If the data from the test submission appears in the webhook response, it indicates a successful connection. This confirms that the integration is functioning as expected and that Jotform submissions will trigger actions in Pabbly Connect.
4. Setting Up Kit as the Action Application
Now that we have confirmed the connection, it’s time to set Kit as the action application in Pabbly Connect. Select Kit from the action application list and choose ‘Tag a Subscriber’ as the action event. This allows us to create a subscriber in Kit whenever a new form submission is received from Jotform.
- Select Kit as the action application.
- Choose ‘Tag a Subscriber’ as the action event.
- Enter your API key and secret from your Kit account.
To obtain your API key, log in to your Kit account, navigate to your profile, and access the settings. Here, you will find the API key and secret. Copy these values back into Pabbly Connect to establish the connection. After entering the required details, select the appropriate tag for the subscriber and map the fields from the Jotform submission to the Kit fields. This ensures that the subscriber information is dynamically populated.
5. Finalizing and Testing the Integration
With both Jotform and Kit configured, it’s time to finalize the integration in Pabbly Connect. Once you have mapped all necessary fields, click on ‘Save and Send Test Request’. This will send a test request to Kit to create a subscriber using the data from the Jotform submission.
Check your Kit account to confirm that the subscriber has been created successfully. If everything is set up correctly, you should see the new subscriber listed under the specified tag. This final step validates that the automation is functioning as intended, allowing you to manage subscribers efficiently through Pabbly Connect.
In this tutorial, we demonstrated how to create a Kit subscriber on Jotform submission using Pabbly Connect. By following these steps, you can automate the process of subscriber creation, ensuring that your leads are managed effectively. This integration not only saves time but also enhances your event management process.
