Learn how to create a Kit subscriber automatically whenever a purchase is made on FlexiFunnels using Pabbly Connect. Step-by-step tutorial included. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
1. Introduction to Pabbly Connect for Kit Integration
In this section, we will explore how to use Pabbly Connect to automate the process of creating Kit subscribers whenever a purchase is made on FlexiFunnels. This integration allows you to streamline your customer engagement efficiently.
Using Pabbly Connect, you can connect your FlexiFunnels account with your Kit account seamlessly. This enables you to add new subscribers automatically, enhancing your email marketing efforts without manual intervention.
2. Setting Up the Pabbly Connect Workflow
To start, log in to your Pabbly Connect account. From the dashboard, click on the ‘Create Workflow’ button located at the top right corner. You will need to name your workflow, such as ‘Create Kit Subscriber on FlexiFunnels Purchase.’ Choose the appropriate folder for your workflow.
- Click on ‘Create’ to initiate your workflow.
- Select FlexiFunnels as your trigger application.
- Choose the trigger event as ‘New Purchase.’ This will activate the workflow when a purchase occurs.
After setting up the trigger, Pabbly Connect will provide you with a webhook URL. This URL is crucial for connecting your FlexiFunnels account to the workflow. Copy this URL for the next steps.
3. Connecting FlexiFunnels to Pabbly Connect
Log into your FlexiFunnels account and navigate to the product settings. Here, select the product for which you want to set up the automation. Click on ‘Edit’ and then go to ‘Set Rules’ in the left sidebar.
- Select the condition that the product is purchased.
- Choose the pricing options applicable for all pricing.
- Set the usage to ‘Webhook’ and enter the webhook URL you copied from Pabbly Connect.
Once you save these settings, your FlexiFunnels account will be successfully connected to Pabbly Connect. This means that every time a purchase is made, the workflow will trigger, and a new subscriber will be added to your Kit account automatically.
4. Adding a Subscriber to Kit via Pabbly Connect
After setting up the trigger, the next step is to configure the action in Pabbly Connect. Select Kit as your action application. For the action event, choose ‘Add Subscriber to a Form.’ This will allow you to add new subscribers to your Kit account based on the data received from FlexiFunnels.
To connect your Kit account, you will need to enter your API key and API secret. You can find these in your Kit account settings under the developer section. Once entered, click on ‘Save’ to establish the connection.
Map the fields from the FlexiFunnels purchase data to the Kit subscriber fields. Ensure you include first name, last name, email, and phone number. Click on ‘Send Test Request’ to verify the integration works properly.
Once the test request is successful, you will see the new subscriber added in your Kit account. This confirms that the workflow is functioning as intended through Pabbly Connect.
5. Verifying the Integration in Kit
To ensure everything is working, navigate to your Kit account and check the subscribers list. You should see the new subscriber created from the test purchase made on FlexiFunnels. This process confirms that Pabbly Connect has successfully integrated your FlexiFunnels purchases with your Kit subscriber list.
By automating this process, you save time and maintain better customer relationships through timely communication. This integration allows you to send important updates and offers without manual effort, enhancing your marketing strategy.
In summary, using Pabbly Connect to integrate Kit with FlexiFunnels allows for automatic subscriber creation upon purchase. This not only streamlines your workflow but also improves customer engagement and communication.
