Learn how to create Kit subscribers automatically from Cognito Forms submissions using Pabbly Connect. This step-by-step guide covers the entire integration process. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
To create a Kit subscriber on Cognito Forms submission, you first need to access Pabbly Connect. This platform enables seamless integration between various applications, including Cognito Forms and Kit. Start by navigating to the Pabbly Connect website and signing in with your credentials.
Upon logging in, you will see a dashboard with multiple options. Select the Pabbly Connect application, which is crucial for connecting your Cognito Forms to Kit. This is where you will create a workflow that automates the subscriber addition process.
In this section, you will create a new workflow within Pabbly Connect. Click on the ‘Create Workflow’ button, and name your workflow appropriately, such as ‘Create Kit Subscriber on Cognito Forms Submission’. Choose a folder to save your workflow, like ‘Automations’.
Once you click on Create, you will be directed to the workflow window. Here, you will set up a trigger and an action. The trigger will be a new submission in Cognito Forms, and the action will be to add a subscriber to Kit. This setup is vital for ensuring that every new form submission is captured and processed.
  • Name your workflow.
  • Select a folder to save the workflow.
After setting up your trigger, you will receive a unique webhook URL. This URL is essential for linking your Cognito Forms account with Pabbly Connect. Copy this URL for the next steps.
Configuring Cognito Forms for Webhook
Next, you need to configure your Cognito Forms account to send data to the webhook URL provided by Pabbly Connect. Log in to your Cognito Forms account and navigate to the specific form you want to connect. In the form settings, enable the option to ‘Post JSON data to a website’ and paste the copied webhook URL.
After pasting the URL, save the changes. This action establishes a connection that allows Cognito Forms to send submission data directly to Pabbly Connect. Ensure that you test this setup by submitting a test entry in your form.
  • Log into your Cognito Forms account.
  • Select the specific form for integration.
  • Enable ‘Post JSON data to a website’ and paste the webhook URL.
Once you have saved the settings, you can proceed to test the workflow by making a test submission in your Cognito Forms.
Adding a Subscriber to Kit
After successfully setting up the webhook in Cognito Forms, return to Pabbly Connect to add a subscriber to Kit. In the workflow, select Kit as the action application and choose the action event as ‘Add Subscriber to a Sequence’. This step is crucial for integrating the data received from Cognito Forms into your Kit account.
You will be prompted to connect your Kit account by entering your API key and API secret. These can be found in your Kit account settings under the developer section. Once connected, select the sequence ID for the subscribers you want to add them to. This ensures that all new subscribers are added to the correct email sequence.
Select Kit as the action application. Choose ‘Add Subscriber to a Sequence’ as the action event. Enter your API key and secret to connect.
After completing these steps, map the fields from the previous trigger step to ensure that the correct data is sent to Kit. This mapping process is essential for dynamic updates based on new submissions.
Testing the Integration
The final step is to test the integration to confirm that everything is working as intended. Go back to your Cognito Forms and make a test submission. After submitting the form, check your Kit account to see if the new subscriber has been added successfully.
In your Kit account, navigate to the subscribers’ section to verify that the details match the information submitted in Cognito Forms. This end-to-end testing ensures that the integration via Pabbly Connect is functioning correctly, allowing for seamless data flow between the two applications.
If the test was successful, you can now automate your email marketing efforts, ensuring that every new lead is promptly added to your Kit subscribers list.
In this guide, we explored how to create Kit subscribers automatically from Cognito Forms submissions using Pabbly Connect. By following the steps outlined, you can streamline your email marketing efforts and enhance your business’s efficiency.
