Learn how to integrate LinkedIn Lead Gen Forms with Kit using Pabbly Connect to automate subscriber creation seamlessly. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
To create Kit subscribers from LinkedIn Lead Gen Forms leads, you first need to access Pabbly Connect. Start by opening your web browser and navigating to the Pabbly Connect website. If you don’t have an account, click on the ‘Sign Up for Free’ button, which takes only a couple of minutes and provides you with 100 free tasks every month.
Once you have logged in, you will be directed to the dashboard. Here, you can create a new workflow by clicking on the ‘Create Workflow’ button. Name your workflow something descriptive, such as ‘Create Kit Subscriber from LinkedIn Leads’. This workflow will automate the process of creating subscribers in Kit whenever a new lead is generated from LinkedIn Lead Gen Forms.
In this step, you will set up the trigger for your workflow using Pabbly Connect. The trigger is essential as it determines when the workflow will execute. Click on the trigger application and search for ‘LinkedIn Lead Gen Forms’. Select this as your trigger application.
  • Choose the trigger event as ‘New Lead Gen Form Response’.
  • Connect your LinkedIn account by clicking on ‘Add New Connection’.
  • Select the specific LinkedIn lead form you are using for your ad campaign.
After setting up the trigger, you will need to generate a test lead through your LinkedIn Lead Gen Form. This test lead will help you confirm that the integration is working correctly. Once a lead is generated, return to Pabbly Connect and click on the ‘Send Test’ button to fetch the response from LinkedIn.
3. Configuring Action to Create Kit Subscriber
Now that your trigger is set up, it’s time to configure the action in Pabbly Connect. The action will determine what happens when a new lead is received. Search for the action application and select ‘Kit’. Then, choose the action event as ‘Add Subscriber to a Sequence’.
Next, connect your Kit account by providing the necessary API key and secret. You can find these by logging into your Kit account, navigating to account settings, and then to the developer section. Copy the API key and secret, and paste them into Pabbly Connect to establish the connection.
  • Select the sequence where you want to add the new subscriber.
  • Map the lead details such as email, first name, last name, and phone number from the LinkedIn response.
  • Ensure all required fields are filled before proceeding.
After mapping the details, click on ‘Send Test’ to verify that the subscriber is created successfully in your Kit account. If successful, you will receive a positive response.
4. Verifying Subscriber Creation in Kit
After successfully setting up the action in Pabbly Connect, it’s time to verify that the subscriber was created in Kit. Navigate to your Kit account and go to the ‘Grow’ section, then select ‘Subscribers’. Here, you should see the new subscriber you just created.
Open the subscriber details to confirm that all the information, such as first name, last name, email, and phone number, matches the data from the LinkedIn Lead Gen Form. This verification step ensures that your integration is functioning as intended and that leads are being captured correctly.
With Pabbly Connect, you have successfully automated the process of creating Kit subscribers from LinkedIn leads. Every time a new lead is generated, it will automatically add them to your Kit account, streamlining your follow-up process.
In this tutorial, you learned how to use Pabbly Connect to create Kit subscribers automatically from LinkedIn Lead Gen Forms leads. This integration not only saves time but also ensures that every lead is effectively nurtured, improving conversion rates.
