Learn how to integrate Facebook Lead Ads with Kit using Pabbly Connect. Follow this step-by-step tutorial to automate subscriber creation effortlessly. Master proven automation processes with practical implementation examples and strategic recommendations you can apply immediately in your workflow.
To start using Pabbly Connect, first visit the Pabbly Connect website by typing ‘Pabbly.com/connect’ in your browser. This platform enables you to create automated workflows between applications like Facebook Lead Ads and Kit.
If you are a new user, click on ‘Sign up for free’ to create an account and receive 100 tasks for free each month. Existing users can click on ‘Sign in’ to access their dashboard.
After signing in, navigate to the Pabbly Connect dashboard. Click on ‘Create Workflow’ to start setting up your automation process. You will need to name your workflow, for example, ‘Create Kit Subscriber for Facebook Lead Ads’. using Pabbly Connect
  • Select the folder for organization.
Once created, you will see two boxes labeled ‘Trigger’ and ‘Action’. The trigger will be Facebook Lead Ads, and the action will be creating a subscriber in Kit.
3. Configuring Facebook Lead Ads as Trigger in Pabbly Connect
In the trigger section, select Facebook Lead Ads as your trigger application. Choose ‘New Lead Instant’ as the trigger event. Click on ‘Connect’ to establish a connection with your Facebook account.
If you don’t have an existing connection, click on ‘Add New Connection’ and authorize Pabbly Connect to access your Facebook account. Once connected, you will need to specify the page name and lead form.
  • Select the Facebook page you are using for ads.
  • Choose the lead form associated with your page.
After selecting the necessary details, click on ‘Save and Send Test Request’ to ensure that the connection is established successfully.
4. Setting Up Kit as Action in Pabbly Connect
Now, navigate to the action section and select Kit as the action application. Choose the ‘Tag a Subscriber’ action event. Again, click on ‘Connect’ to link your Kit account with Pabbly Connect.
You will need to input your API Key and API Secret from your Kit account. After entering these details, click on ‘Save’. This connection allows Pabbly Connect to create subscribers in your Kit account whenever a new lead is received.
Enter the tag ID for the subscriber. Map the email address and first name fields from the response received from Facebook Lead Ads.
Click ‘Save and Send Test Request’ again to confirm that the subscriber is created successfully in your Kit account.
To test the integration, submit a test lead through your Facebook Lead Ads form. Make sure to refresh the page and check that the data is captured in Pabbly Connect. You should see the lead details populated correctly.
Next, check your Kit account to confirm that the subscriber has been created under the specified tag. Repeat the process with different test leads to ensure everything is functioning as expected.
By following these steps, you have successfully integrated Facebook Lead Ads with Kit using Pabbly Connect. This automation will save you time and streamline your lead management process.
In this tutorial, we explored how to create a Kit subscriber for Facebook Lead Ads using Pabbly Connect. By following the steps outlined, you can automate subscriber creation seamlessly and enhance your lead management capabilities.
