Learn how to integrate Cashfree Payment with GoToTraining using Pabbly Connect to automate registrant creation effortlessly. Follow this step-by-step guide! Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
To create a GoToTraining registrant on Cashfree Payment, you first need to access Pabbly Connect. Start by typing the URL Pabbly.com/connect in your browser. This will lead you to the Pabbly Connect homepage.
Once there, you’ll see options to either sign in or sign up for free. If you’re an existing user, click on the ‘Sign In’ button. New users can click on ‘Sign Up for Free’ to create an account, which only takes a couple of minutes. After signing in, you’ll be directed to the All Apps section where you can access Pabbly Connect.
After accessing Pabbly Connect, you need to create a new workflow. Click on the ‘Create Workflow’ option. A dialog box will appear asking for a name for your workflow. Enter ‘Create GoToTraining Registrant on Cashfree Payment’ and select an appropriate folder for this automation.
  • Choose a folder related to webinars and meetings.
This will open a new screen with two main sections: Trigger and Action. The trigger will be Cashfree, and the action will be GoToTraining. This setup allows you to automate the process of adding registrants when a payment is made through Cashfree.
3. Setting Up the Trigger with Cashfree
In this step, you will set up the trigger using Cashfree within Pabbly Connect. Select Cashfree as your trigger application and choose the event as ‘Payment via Form’ to capture the response whenever a payment is made.
Once you select the trigger event, you’ll receive a webhook URL. This URL is crucial as it acts as a bridge between Cashfree and Pabbly Connect. Copy the webhook URL and navigate to your Cashfree account. Go to the Developers section, select Webhooks, and click on ‘Add Webhook’ to paste the URL.
4. Capturing Payment Response in Pabbly Connect
After setting up the webhook in Cashfree, return to Pabbly Connect and click on ‘Recapture Webhook Response’. This action will allow you to capture a test response. To do this, you need to perform a test payment using the form you set up in Cashfree.
Make a test payment by entering the necessary details such as email and phone number. After successfully making the payment, switch back to Pabbly Connect to see the captured response, which will include all relevant details like transaction ID, amount, and customer information.
5. Creating a Registrant in GoToTraining
Now that you have captured the payment response, it’s time to create a registrant in GoToTraining using Pabbly Connect. Select GoToTraining as your action application and choose the action event as ‘Create Registrant’. Click on ‘Connect’ to establish the connection.
Map the details from the captured response to the required fields in GoToTraining, such as email, first name, and last name. If the name is combined, use the Text Formatter feature in Pabbly Connect to split it into first and last names. After mapping all fields, click on ‘Save and Send Test Request’ to finalize the setup.
Once the registrant is created successfully, you can check in your GoToTraining account to confirm that the new registrant is added. This automation ensures that every time a payment is made through Cashfree, the registrant is automatically added to your webinar.
Using Pabbly Connect, you can seamlessly integrate Cashfree Payment with GoToTraining to automate the registration process. This setup saves time and ensures efficiency in managing webinar registrations effortlessly.
