Learn how to integrate FlexiFunnels with GetResponse using Pabbly Connect for automatic contact creation upon form submissions. Step-by-step tutorial included. Master proven automation processes with practical implementation examples and strategic recommendations you can apply immediately in your workflow.
To create GetResponse contacts on FlexiFunnels form submission, we will use Pabbly Connect. First, access Pabbly Connect by visiting the Pabbly website and logging in to your account. If you are new, you can sign up for free and get 100 tasks monthly.
After logging in, you will see the dashboard with various Pabbly applications. Click on Pabbly Connect to start setting up your integration. This platform will facilitate the connection between FlexiFunnels and GetResponse seamlessly.
Next, we will create a workflow in Pabbly Connect. Click on the button that says ‘Create Workflow’. You will be prompted to name your workflow and choose a folder for saving it. For this integration, name it ‘Create GetResponse Contacts on FlexiFunnels Form Submission’ and save it in the automations folder.
  • Workflow Name: Create GetResponse Contacts on FlexiFunnels Form Submission
  • Folder: Automations
After naming your workflow, click on ‘Create’. You will now see the workflow window, where you can set your trigger and action applications. In this case, the trigger will be FlexiFunnels, which will notify Pabbly Connect whenever a new form is submitted.
3. Setting Up the Trigger with FlexiFunnels
In this step, we will set up the trigger application in Pabbly Connect. Search for FlexiFunnels and select it as your trigger application. For the trigger event, choose ‘New Form Submission’. This action will generate a webhook URL that you will use to connect FlexiFunnels with Pabbly Connect.
Copy the webhook URL provided and navigate to your FlexiFunnels account. Go to the Project Settings, select Integrations, and edit the page where you want to set up the webhook. Paste the copied URL into the Webhook URL field, give it a name (e.g., Test), and save the changes.
4. Configuring GetResponse in Pabbly Connect
Now that we have set up the trigger, it’s time to configure the action in Pabbly Connect. For the action application, select GetResponse. Choose the action event as ‘Create Contact’. Click on ‘Connect’ and either select an existing connection or create a new one by entering your API key.
To get your API key, you can generate a new key in your GetResponse account. After creating the key, paste it into Pabbly Connect and click Save. Once connected, you can proceed to map the fields from your FlexiFunnels form submission to GetResponse, ensuring that the contact details are accurately transferred.
  • Action Application: GetResponse
  • Action Event: Create Contact
  • API Key: Generated from GetResponse
After mapping the required fields like name, email, and phone number, click on ‘Save and Send Test Request’ to verify that the integration works correctly. If successful, you will see a confirmation message indicating that the contact has been created in GetResponse.
Finally, we need to test our integration to ensure everything works as expected. Fill out the form in FlexiFunnels again with new data and submit it. Pabbly Connect will capture this new submission and trigger the action to create a contact in GetResponse.
After submitting the form, check your GetResponse account to see if the new contact appears. This confirms that the integration is functioning correctly, allowing you to automate the process of adding contacts from FlexiFunnels to GetResponse using Pabbly Connect.
By following this tutorial, you have successfully learned how to create GetResponse contacts on FlexiFunnels form submission using Pabbly Connect. This integration streamlines your workflow and automates contact management efficiently, enhancing your marketing efforts.
