Learn how to automate the creation of GetResponse contacts from AWeber subscribers using Pabbly Connect. Follow this step-by-step guide for seamless integration. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
1. Accessing Pabbly Connect for AWeber and GetResponse Integration
To start the integration process between AWeber and GetResponse, first access Pabbly Connect. This platform allows you to automate tasks easily without coding. Sign up for a free account on the Pabbly Connect website to get started.
Once signed up, log into your Pabbly Connect dashboard. Here you will find the option to create a new workflow. Click on the ‘Create Workflow’ button to begin the integration setup.
After reaching the dashboard of Pabbly Connect, click on the ‘Create Workflow’ button and provide a suitable name for your workflow. This name will help you identify the integration later.
Next, you will set up the trigger and actions for your automation. The trigger will be a new subscriber in AWeber, while the action will be to create a contact in GetResponse. This setup will enable automatic data transfer from AWeber to GetResponse.
  • Click on the trigger application and select AWeber.
  • Choose the trigger event as ‘New Subscriber in a List’.
  • Connect your AWeber account by allowing access.
After completing these steps, you will be able to fetch data from the latest subscriber added in AWeber.
3. Fetching Subscriber Data from AWeber
To fetch subscriber data, ensure that a new subscriber has been added to your AWeber list. For this tutorial, we will use a demo sign-up page created in AWeber. Fill in the required fields and submit the form to register a new subscriber. using Pabbly Connect
Once the subscriber confirms their email, go back to your Pabbly Connect workflow. Click on ‘Save and Send Test Request’ to retrieve the latest subscriber’s data. You should see the subscriber’s details appear in the response section.
  • Ensure the subscriber’s name and email address are correctly displayed.
  • Review the fetched data for accuracy before proceeding.
This step is crucial as it ensures that the data from AWeber is correctly captured for the next action.
4. Creating a Contact in GetResponse Using Pabbly Connect
Now, it’s time to create a contact in GetResponse with the data fetched from AWeber. In your Pabbly Connect workflow, select GetResponse as the action application and choose ‘Create Contact’ as the action event. using Pabbly Connect
To connect GetResponse, you will need to provide your API Key. Click on the word ‘here’ to navigate to the GetResponse API page, where you can generate your API Key. Once you have the key, paste it into the connection field in Pabbly Connect.
After connecting, select the campaign where you want to add the new contact. Map the fetched subscriber data to the required fields in GetResponse, such as name and email address. Click ‘Save and Send Test Request’ to finalize the action.
5. Verifying Contact Creation in GetResponse
After completing the setup in Pabbly Connect, it’s essential to verify that the new contact has been added to GetResponse. Refresh your GetResponse contacts list to see if the new subscriber appears.
If the integration was successful, you should see the new contact listed with the details you provided. This confirms that the automation between AWeber and GetResponse via Pabbly Connect is functioning correctly.
Once set up, this automation will trigger every time a new subscriber signs up, ensuring that your marketing efforts are streamlined and efficient.
In this tutorial, we explored how to use Pabbly Connect to automate the creation of GetResponse contacts from AWeber subscribers. By following these steps, you can enhance your marketing automation and ensure seamless data transfer between platforms.
