Learn how to automate the creation of Flodesk subscribers from ThriveCart bump purchases using Pabbly Connect in this detailed tutorial. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
To create a Flodesk subscriber from a ThriveCart bump purchase, first, access Pabbly Connect. This platform is essential for integrating your applications seamlessly.
Begin by visiting the Pabbly Connect website. If you are a new user, you can sign up for free, which allows you to execute 100 tasks each month. Existing users should simply sign in to their accounts to proceed with the integration.
Once signed in to Pabbly Connect, navigate to the dashboard and click on the button labeled ‘Create Workflow’. This action initiates the setup for your automation.
In the dialog box that appears, you will need to provide a name for your workflow. Enter ‘Create Flodesk Subscriber on ThriveCart Bump Purchase’. After naming your workflow, select the appropriate folder to save it in, like ‘ThriveCart Automations’. Finally, click ‘Create’ to establish your workflow.
- Select a folder to organize your workflows.
- Click ‘Create’ to finalize the setup.
After creating the workflow, you will see two sections labeled ‘Trigger’ and ‘Action’. Setting up these components is crucial for your automation to work effectively.
The next step involves setting up the trigger in Pabbly Connect. Click on the trigger section and select ‘ThriveCart’ as your trigger application.
For the trigger event, choose ‘Bump Purchase’. This selection indicates that the workflow will be activated whenever a bulk purchase occurs through ThriveCart. After selecting the trigger, click on ‘Connect’.
- Choose ‘ThriveCart’ as the trigger application.
- Select ‘Bump Purchase’ as the trigger event.
- Click ‘Connect’ to link to ThriveCart.
This step ensures that Pabbly Connect is prepared to capture data from ThriveCart whenever a purchase is made.
4. Connecting ThriveCart to Pabbly Connect
To connect ThriveCart with Pabbly Connect, you will need an API key from your ThriveCart account. Go to your ThriveCart dashboard, click on your profile, and then select ‘Settings’.
Under the ‘API and Webhooks’ section, you will see options to create an API key. Click on ‘View Settings’, and then create a new API key by naming it (e.g., ‘Test Connection’). Copy this key and paste it back into Pabbly Connect to finalize the connection.
Access ‘Settings’ from your ThriveCart profile. Create a new API key and name it. Copy the key and return to Pabbly Connect.
After pasting the API key in Pabbly Connect, click ‘Save’ to establish the connection. This integration allows Pabbly Connect to receive purchase details from ThriveCart.
5. Setting Up the Action in Pabbly Connect
Now that the trigger is set up, it’s time to configure the action in Pabbly Connect. Click on the action section and select ‘Flodesk’ as your action application.
For the action event, choose ‘Create/Update Subscriber’. This action will create a new subscriber in Flodesk whenever a purchase is made on ThriveCart. Click ‘Connect’ to link Flodesk to Pabbly Connect.
Select ‘Flodesk’ as the action application. Choose ‘Create/Update Subscriber’ as the action event. Click ‘Connect’ to link Flodesk.
After connecting, you will need to map the fields, such as email, first name, and last name, from the ThriveCart purchase data to the corresponding fields in Flodesk. This mapping ensures that the subscriber information is accurately transferred.
In this tutorial, we explored how to create a Flodesk subscriber from a ThriveCart bump purchase using Pabbly Connect. By following the steps outlined, you can automate your subscriber management efficiently.
Utilizing Pabbly Connect simplifies the integration process, ensuring that your customer information is captured and utilized effectively. Automate your workflows today for better efficiency!
