Learn how to integrate Razorpay with Flodesk to create subscribers automatically using Pabbly Connect. Step-by-step guide included. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
To create a Flodesk subscriber from Razorpay payments, you first need to access Pabbly Connect. Start by visiting the Pabbly Connect landing page, which can be found by searching for it in your browser.
Once on the page, you will see two options: ‘Sign In’ and ‘Sign Up for Free’. If you are a new user, select ‘Sign Up for Free’ to get started with 100 tasks free every month. Existing users should click on ‘Sign In’ to access their dashboard.
After signing in, navigate to your dashboard and click on the ‘Create Workflow’ button. This is where you will set up the integration between Razorpay and Flodesk using Pabbly Connect.
  • Enter a name for your workflow, such as ‘Create Flodesk Subscriber from Razorpay Payment’.
  • Choose a folder to save the workflow, for example, ‘Automations’.
Once the workflow is created, you will see the workflow window where you can set up the trigger and action. In this case, Razorpay will be the trigger application, and Flodesk will be the action application.
3. Setting Up Trigger with Razorpay
In the workflow window, select Razorpay as the trigger application. This means that the workflow will be activated when a new payment is captured in your Razorpay account. Choose the trigger event as ‘Payment Captured’.
After selecting the trigger, Pabbly Connect will provide you with a webhook URL. Copy this URL as you will need it to connect Razorpay with your workflow.
  • Log in to your Razorpay account and navigate to the ‘Developers’ section.
  • Click on ‘Webhooks’ and then select ‘Add New Webhook’.
  • Paste the copied webhook URL and select ‘Payment Captured’ for active events.
Finally, click on ‘Create Webhook’ to establish the connection between Razorpay and Pabbly Connect. This step ensures that your workflow will be triggered each time a payment is made.
4. Testing the Integration
After setting up the webhook, it’s important to test the integration to ensure everything is working correctly. You can do this by making a test payment through Razorpay.
To perform a test payment, use the payment link generated for your product. Fill in the required details, such as name, email, and mobile number, and complete the payment process. Once the payment is successful, Pabbly Connect will capture the payment response automatically.
Open your workflow in Pabbly Connect to check if the payment details have been captured. Verify that the captured data includes the first name, last name, email, and payment details.
If the details are successfully captured, you are ready to proceed to the next step of creating a subscriber in Flodesk.
5. Creating a Subscriber in Flodesk
With the payment details captured, the next step is to create a subscriber in Flodesk. For this, select Flodesk as the action application in your workflow.
Choose the action event as ‘Create or Update a Subscriber’. If you have not connected your Flodesk account yet, click on ‘Add a New Connection’ to log in and authorize Pabbly Connect to access your Flodesk account.
Map the fields from the Razorpay payment response to the corresponding fields in Flodesk. Select the email, first name, and last name from the captured payment response. Decide whether to send an opt-in confirmation email to the subscriber.
Once you have mapped the fields, click on ‘Save and Send Test Request’. If successful, a new subscriber will be created in your Flodesk account with the details from the test payment.
In this tutorial, we explored how to create a Flodesk subscriber from Razorpay payments using Pabbly Connect. By following the steps outlined, you can automate the process of adding subscribers whenever a payment is received. This integration enhances your workflow efficiency and ensures that your email lists are updated in real-time.
